View Poll Results: Should I? Please take my setup and n00b skills into account.
Yes
100.00%
No
0%
Voters: 3. You may not vote on this poll
Entry level SQ: Should I replace the stock speaker wire?
Sounds like a PITA. With my setup, will the upgrade be audible? I won't be running anything crazy, SLC265s in the front powered by a DA3400.4, with the rear stock 6.5s powered by an AVIC-D2.
how are you wiring the fronts from the amp? The amp is a 4channel amp, why dont you run it to the back also? If you dont, replacing the rear wires wont do much since it is powered by a HU. In the long run it is worth it incase you run anything in the rear.
I have the same amp and speakers up front. Bridge the amp, it gets quite a bit louder. Something it took me a little while to figure out was to plug the rcas into either both reds or both whites (I've never bridged a 4ch amp, but this is how you get stereo).
Ok, then yah bridge it because I run 85rms all around and it is needed for my SLC's and SL's. I will probably upgrade to 100rms all around after I complete my sub upgrade. You dont need to run speaker wire to the rears then.
Originally Posted by KyMan
Running new wires to the front door is a PITA. I just used the stock wires to the doors, but ran new wires for the tweeters and obviously from the amp to the xovers.
Just run all new wires for the front. It isnt hard at all. That stupid grommet is the only thing that held me up.
Steve, I got you.
It's a little different for 5th gens.
Steve, I got you.
Steve, I got you.
OT- why won't the pic appear in the post? I'm doing [img]URL[/img]
4th gens FTL. j/k I seriously wouldn't mind a 4th gen (same engine, less weight). The 5th gen has an atrocious turning radius-cruise liners turn sharper.
anyhow, definately run new wires. the grommet on my 6th gen was a b*tch to work with, but persistence pays off. I have four 14 gauge wire crammed into the grommet.
Can it really make that much difference if you change your speaker wire? I have a 5.5 gen.. i dont really feel like doin all the work to rewire and am just going to use the stock wire.. btw i am powering all 4 speakers with a rockford p4004 50rms a channel.. do you think i will be ok?
jskirwin
06-08-2016 08:49 AM
vingodine
45
05-21-2016 12:46 PM
Maxilano
08-31-2015 07:33 PM
