just a quick question
Old Aug 11, 2006 | 11:24 PM
craigl33's Avatar
re: 1996 gle bose system
if i remove the stock head unit will there be connectors behind it where i can connect stripped audio rca cables to?
Old Aug 12, 2006 | 04:28 AM
kcryan's Avatar
if you do some cutting, or if you get an A/M harness
Old Aug 12, 2006 | 05:39 AM
craigl33's Avatar
please explain? and what's an A/M harness?
Old Aug 12, 2006 | 05:55 AM
kcryan's Avatar
aftermarket wiring harness, look em up on like crutchfield.com
Old Aug 12, 2006 | 07:57 AM
craigl33's Avatar
this seems to be it. so i can connect rca wires to the bare wires?
http://www.crutchfield.com/S-jy24GHj...ss&i=120707550
what's the "sub" and "main" prongs in this
http://www.carstereohelp.net/wireharness_Nissan2.htm
Old Aug 12, 2006 | 09:14 AM
Hexon's Avatar
No, no, no! You have to buy a line out converter http://www.crutchfield.com/S-IgugZ69...=721&I=142SLC4. Then you tap into the + and - wire going to one of your rear speakers if you are adding a sub.
Old Aug 12, 2006 | 03:34 PM
kcryan's Avatar
you dont have to, but yes, that is the best way too...
Old Aug 12, 2006 | 05:16 PM
craigl33's Avatar
a line out converter basically splits audio signals into 4 channels right? can't i achieve the same effect by just stripping wires and making Y splits?
Old Aug 12, 2006 | 05:36 PM
craigl33's Avatar
ok so i want to completely remove the bose headunit. not use it at all because i want to put a lcd there. i would like to get audio from a carputer and use the car's speakers.
Pac Aoem-nis2?
Old Aug 12, 2006 | 05:57 PM
kcryan's Avatar
Get an different headunit with AUX inputs, and use those, then you keep radio and all
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
Johnny9595
Sep 3, 2015 05:18 AM
