audio diagram needed
Old Aug 19, 2006 | 05:48 AM
airmanhoward's Avatar
where can i find a audio wireing diagram for my 94 max
Old Aug 19, 2006 | 06:54 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Before you go to all that trouble, what do you need it for?
Old Aug 19, 2006 | 11:30 AM
prem's Avatar
There are some wiring diagrams and the end of Haynes manual
Old Aug 19, 2006 | 03:13 PM
i need to hook up my cd player in my car ad i went to the auto parts store and they dont have any manuals for the max they said it will be 3 to 5 days befor i can get one
Old Aug 19, 2006 | 03:18 PM
ManualMaxFan's Avatar
See if these work for you
http://installdr.com/Harnesses/Nissan-Wiring.pdf
http://installdr.com/InstallDocs/Nissan/PDF/647021.pdf
Old Aug 19, 2006 | 10:17 PM
djfrestyl's Avatar
Suspension Yoda
You don't need wire colors for a CD player...all you need is a harness, noob.
Old Aug 20, 2006 | 06:08 AM
Ok I Got Everything Now But When I Turn My Car Off The Deck Resets Itself Which Wire Is The Memory Wire?
Old Aug 20, 2006 | 07:20 AM
djfrestyl's Avatar
Suspension Yoda
You didn't hook it up right. Double check where your +12v (constant) wire is going. This wouldn't have been a problem if you used a harness.
Old Aug 20, 2006 | 10:08 AM
kpr10is's Avatar
And if all the newbs stopped thinking they know what theyre doing and took our advice, they wouldnt have any retarded questions to post, and this forum wouldnt exist.
Old Aug 20, 2006 | 11:34 AM
nismos14's Avatar
§è~® f®ÈÄk
This forum would still exist, for all of us post ******.
Old Aug 20, 2006 | 11:58 AM
sucanushie's Avatar
Sorry for thread jacking but i cannot create a thread...
I just installed a new deck in a 94 maxima... I used a harness and everything seems to be working but my back speakers... I hooked up the stock tape deck to see if my new speakers didn't work but they work fine with the tape deck. I hook my new deck back up nothing from the rears. I have tried everything. Thinking it may be the harness or even the deck itself. Has anyone else run into this prob?
Old Aug 20, 2006 | 02:47 PM
djfrestyl's Avatar
Suspension Yoda
How did you wire your new deck to the rear speakers?
If you read the info, you would know that you can't make a new thread until you have 15 posts.
Old Aug 20, 2006 | 02:56 PM
Dear God, whay are you still using tapes?!
Oh, you're Canadian...n/m
Old Aug 20, 2006 | 03:06 PM
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
"A dvd payer??? where do you put the syrup eh?" - the simpsons
lol anyway i couldnt help it
Old Aug 20, 2006 | 03:18 PM
sucanushie's Avatar
No no i just hooked the tape deck back up to test the rear speakers...
I used a harness to wire the deck to the rear speakers...
Old Aug 20, 2006 | 04:42 PM
What About Me Can Someone Just Tell Me The Color Of The Memory Wire Thx
Old Aug 20, 2006 | 05:23 PM
prem's Avatar
There isn't exactly a "Memory wire". If there is a memory reset, your radio loses power from the battery.
When the car is turned off, battery wire is either pink / pink & blue for ur 95 max
goodluck
Old Aug 21, 2006 | 05:22 AM
goodluck
**** i didnt up date my profile i have a 94 will that make a differance
Old Aug 21, 2006 | 10:38 PM
prem's Avatar
in that case, on a 94 without the bose, battery wire is brown and white
Old Aug 22, 2006 | 06:32 PM
thx i will try 2morrow
Old Aug 22, 2006 | 07:05 PM
sucanushie's Avatar
Is there a built in amp that will only work on a stock HU on a '94 maxima?
I hooked up an after market deck and now only the front speakers work. I have tried a new harness, a new deck. Still the same thing. I am positive that the deck is hooked up properly. I have installed decks in tons of Honda/Acura and have never seen this happen. Someone was telling me that Maximas have a built in amp. This is not a Bose HU just a tape deck if that helps. If I plus the stock HU back in rear speakers work.
Does anyone have any suggestions?
Old Aug 22, 2006 | 09:56 PM
maximal's Avatar
go to your trunk and look under your rear deck. you should have some small amps right next to your rear speakers.
Old Aug 23, 2006 | 03:36 AM
sucanushie's Avatar
how do i disable them?
Old Aug 23, 2006 | 04:54 PM
sucanushie's Avatar
Does anyone know how to disable the amp for the rear speakers so my rear speakers will work with my aftemarket deck? This is not a Bose system. '94 maxima
Old Aug 23, 2006 | 05:05 PM
djfrestyl's Avatar
Suspension Yoda
Just unplug it
Old Aug 23, 2006 | 05:21 PM
sucanushie's Avatar
do i have to re wire the speakers?
Old Aug 23, 2006 | 06:45 PM
djfrestyl's Avatar
Suspension Yoda
What is your ultimate intention?
Old Aug 24, 2006 | 03:22 AM
sucanushie's Avatar
for my rear speakers to work. Right now they only work if the factory deck is hooked up.
Old Aug 24, 2006 | 07:20 PM
djfrestyl's Avatar
Suspension Yoda
Then you wired something wrong.
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
doobadoo
Aug 15, 2015 06:43 PM
Slamrod
Aug 10, 2015 12:33 PM
MikesChevelle
Aug 9, 2015 11:50 AM
