Those using Metra 70-7551 (help)
Old Aug 23, 2006 | 11:09 PM
STang57's Avatar
i have a 96 I30 with BOSE. i bought the METRA 70-7551 so i can use an aftermarket HU with the factory speakers. the problem i believe is with the remote wire(s). the HU harness has 1 blue wire while the METRA kit has two (1 on each harness). the blue says power antenna while the other blue/white says amp turn on. once i connect it to the HU blue, something by my passenger door clicks and when i turn on the HU it immediately turns back off then on and off again and again until i turn off the ignition. i've tried different combinations including 1 blue at a time, each one to red constant, yellow, etc. i dont have a voltmeter in case that would help at all. but any advice is appreciated. i've been without radio approx 2 months and drive almost 100mi daily. thanks in advance!
~STEVE
Old Aug 24, 2006 | 12:26 AM
STang57's Avatar
found it in the stickies FAQ. grounding problem
melteye
May 16, 2016 12:02 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
BrandonCause
Sep 20, 2015 10:20 PM
Sari
Mar 21, 2007 08:36 PM
