Amp Box
Old Sep 4, 2006 | 07:32 PM
Penguin215's Avatar
Amp Box
I am curious to know how you guys have mounted your amps. My old one was small enough to mount on the back of the larger fold down seat, and held on rather well. My new one is heavier and longer, so just won't work mounted on the back of the seats.
What I did yesterday was build a base out of MDF, and three sides, leaving the fourth open for the wires to get through. Right now its just kind of laying in the trunk, and I have so ideas on how I might keep it in place(having some sort of L-shaped bracket screw onto the box, and the other end onto the metal behind the seats).
Any suggestions? I don't have much room to move it, as the power wire doesn't have more than maybe 16" of slack from coming out from under the seats.
Old Sep 4, 2006 | 07:51 PM
djfrestyl's Avatar
Suspension Yoda
Pics of what you built would help.
Old Sep 4, 2006 | 08:48 PM
Penguin215's Avatar
Sorry for the bad quality, but that is what it looks like, the lighter grey is the box. Right now it's on a giant pillow, to make it pretty level, and help prevent it from sliding around.
Old Sep 4, 2006 | 09:56 PM
DcMaN's Avatar
thats how mine is mounted :P
Old Sep 4, 2006 | 10:00 PM
Penguin215's Avatar
So went into the spare tire area, did you remove the spare tire?
Also, if I wanted to extend the power cable, instead of completely rewiring, which I really don't want to do, I have an extra inline fuse holder, since my amp is rated at 80a, could I "extend" the cable with another fuse holder, and put a 40a fuse in each? Also, i'd go to a larger gauge wire after the second holder, as it's all I have left :/ Would this be ok?
Old Sep 5, 2006 | 02:30 AM
djfrestyl's Avatar
Suspension Yoda
See link in sig for a solution.
Old Sep 5, 2006 | 08:31 AM
metallic97gxe's Avatar
Master Will
just get some 1 1/4" cabinet or sheet metal screws and drill them through the mdf into the trunk floor..ohh my amp is only a acuated rack...
mmmuuuuhhhaaaa
Old Sep 5, 2006 | 08:49 AM
nismopc's Avatar
Your amp appears to be about the same dimensions as mine. I attached a 1/4" mdf board to the rear driver side fender area and mounted my amp there...
As for extending your power cable, go to electronics store or HomeDepot/Lowes. They have couplers that handle up to 0 gauge wires that allow you to extend a power cable easily. Only issue is there is no protective cover, so you will either need to use heat shrink wrap or electrical tape to rap the coupler.
Old Sep 5, 2006 | 09:04 AM
DcMaN's Avatar
you can also get a unfused distrobution block with a cover to extend the wire.
Old Sep 5, 2006 | 04:18 PM
Penguin215's Avatar
Ok, borrowing from the collective inputs i've seen here, i've decided on this.
Make a 3 piece template that is basically the layout of the trunk, use a thin MDF, and do the three pieces(side, middle for spare, and other side). I'll bolt the amp to the middle piece, and voila!
Sounds like it'll work to me, did I miss anything?
Old Sep 5, 2006 | 04:33 PM
djfrestyl's Avatar
Suspension Yoda
You missed the part where you buy a spare tire cover from me
Old Sep 5, 2006 | 07:55 PM
Penguin215's Avatar
I just built a new computer along with getting the new amp and speakers, where might this money be coming from?
Old Sep 5, 2006 | 08:43 PM
BLK2BLU's Avatar
This is how I did mine
Old Sep 5, 2006 | 08:55 PM
godlyone's Avatar
ahhh! cliMAX!
why not just make a simple box and mount amp on top of it?
chisam14
Nov 6, 2018 08:56 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Sep 27, 2015 08:37 AM
