2.2 Volt preamp outs?
Old Sep 18, 2006 | 03:21 PM
k3v's Avatar
k3v
Are 2.2v preamp outputs enough to run bose speakers at a good volume? i was looking into buying a Pioneer DEH-P5800MP for $180. Any better suggestions? looking for something under $200
Old Sep 18, 2006 | 04:22 PM
1996blackmax's Avatar
If you are concerned with preout voltate, you could get an Eclipse HU for around that price with 5v preouts.
By the way, the preout voltage will not be running your speakers. That is what the amp will be doing.
Old Sep 18, 2006 | 05:36 PM
kpr10is's Avatar
If hes looking to add an aftermarket radio to Bose, then if wired correctly, his preouts will be powering his speakers.
No, 2.2v will not be enough. Get an Eclipse, or a deck with at least 4v preouts if you want your preouts to power your stock speakers.
Old Sep 18, 2006 | 05:58 PM
djfrestyl's Avatar
Suspension Yoda
Just to clarify even further, the preout will still be giving signal to the bose amp, THEN the speakers.
Old Sep 18, 2006 | 06:50 PM
k3v's Avatar
k3v
ok thanks for the help. Looks like the CD 2000 ($186 total) is the only one within my range. two more questions though...does it include mouting brackets? and how hard is it to get the factory bose headunit out? i have a 98 se.
Old Sep 18, 2006 | 06:52 PM
djfrestyl's Avatar
Suspension Yoda
You don't need brackets, your HU will mount to the OEM radio mounting brackets.
The screws are a bit of a PITA to get the Bose HU out of the bracket Use a #2 phillips, press firmly, TIGHTEN till you hear the screw click, then loosen.
Old Sep 19, 2006 | 07:25 AM
k3v's Avatar
k3v
ok so im sitting here in class and pulled up crutchfield looking for a head unit with more bells and whitles than the CD2000. I found the JVC KD-G820 ($184 buy.com). I really like the usb flash drive feature. and the voltage on the preamp outputs are 4v for the front and rear, 2v for subwoofer.
I know that everyone recommends all the high quality and high priced head units, but im just looking for something decent for a decent price. What do you guys think about the JVC unit?
Heres a link to it:
http://www.crutchfield.com/S-zkMeHvF...00&I=257KDG820
Old Sep 19, 2006 | 08:12 AM
nismos14's Avatar
§è~® f®ÈÄk
The jvc is ALRIGHT, but the cd2000 will sound better.
Old Sep 19, 2006 | 09:56 AM
k3v's Avatar
k3v
Correct me if im wrong but both of those head units (the jvc and cd2000) will sound better than the factory bose unit, right?
Old Sep 19, 2006 | 01:20 PM
djfrestyl's Avatar
Suspension Yoda
Yea. Definitely the CD2000, probably the JVC.
Old Sep 19, 2006 | 06:30 PM
k3v's Avatar
k3v
Alright, im pretty sure that im going to go with the JVC. If i hate it i can always return it and get the cd2000. Thanks for all the all the help and ill let you guys know how things go.
Old Sep 20, 2006 | 03:03 PM
djfrestyl's Avatar
Suspension Yoda
I wouldnt "" if I were you. Go with the Eclipse.
Old Sep 20, 2006 | 05:32 PM
Why not do it right the first time around ...
CorollaULEV
30
Aug 9, 2021 08:11 PM
homeyclaus
Sep 3, 2015 06:15 PM
doobadoo
Aug 15, 2015 06:43 PM
bassmann
Aug 13, 2015 10:13 PM
