hows hard is it...
Old Sep 28, 2006 | 10:04 PM
gmax96's Avatar
hows hard is it...
to change the front and rear speakers on a non bose 96 maxima? i mean do i have to splice wires or what not or is it pretty much plug and play.... thanks
Old Sep 29, 2006 | 10:53 AM
jpm36's Avatar
would like help on the same situation for my 96 max non bose. Just picked up some speakers for the rear today, but the hook up is different from the factory ones. The factory speakers had a wire plug in directly to the speaker itself. Can i buy an adapter or something to hook into the factory plug in and then hook it into the hookup with the speakers i just bought? Or do i have to strip the wires and just wrap them around the hookups for the new speakers? Any advice on to where I could pick up such an adapter, or which wires are the positive and negative ones. I have red and green wires on the left rear side of the car, and blue and pink on the right rear side. Thanks in advance for helping an inexperienced installer out.
Old Sep 29, 2006 | 11:16 AM
kpr10is's Avatar
If its a small brown harness that plugs into the factory speaker, than CC sells adapters thatd make it plug and play, for 11 bucks a pair iirc. Or you can get female quick disconnects, cut off the factory plug, and crimp on your disconnects.
Old Oct 1, 2006 | 07:18 AM
gmax96's Avatar
is this gonna be the same wiring as the front speakers?
Old Oct 1, 2006 | 09:17 AM
kpr10is's Avatar
The colors will not be the same, but if you look in the trunk and see that the harnesses plugged into the rears are small, almost square, and brown, then yes, you will also have those harnesses plugged into your fronts.
The speaker harness adapters are Metra 72-7400 or DW-7400SH (the same thing)
Old Oct 3, 2006 | 04:18 PM
jpm36's Avatar
^^^ took me a saturday afternoon running around the state of CT to find that adapter, but after i got it it was a nice easy plug and play swap.
fastcarny
Oct 6, 2015 10:42 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
slowlifer
Sep 8, 2015 05:53 AM
trungg86
Sep 4, 2015 04:58 AM
