Trunk light... no juice??
Old Jun 28, 2001 | 04:37 PM
Speebs's Avatar
I aim to misbehave.
I just realized that my trunk light isn't working. I don't know if it ever worked, as I bought the car used a couple of years ago. I replaced the bulb and it still isn't working, so my question is this:
What should I check? Where does the power line go through the car? I assume something just came loose.
Thanks,
Speebs
Old Jun 29, 2001 | 09:28 AM
jashick's Avatar
Thanks,
Speebs
Did you notice any other light not working?
Did you check the fuse?
Old Jun 29, 2001 | 12:26 PM
Speebs's Avatar
I aim to misbehave.
All other lights seem to be working fine. I haven't yet checked the fuse, I don't know why I didn't think of that. I'll check that, but I'm completely ignorant; what am I looking for (how can I tell if there's something wrong with the fuse)??
Old Jun 29, 2001 | 04:01 PM
jashick's Avatar
Get a hold of a multimeter and do a continuity test from the two seperate contacts. If there is continuity the fuse is ok. If not, the fuse is blown. So check it out and replace if necessary.
If the fuse is good, then take the multimeter and check the voltage at the trunk light socket.
Old Jun 29, 2001 | 09:48 PM
niceorange's Avatar
theres no way that nissan used a seperate fuse to power a TRUNK LIGHT!!!! check the switch that activates the light, it may be gummed up and not opening all the way
Old Jun 30, 2001 | 10:35 AM
DaBoxSE's Avatar
Do you have a 3rd or 4th gen? i ask this because i was told that in the third gens, the problem is in the trunk latch on the trunk lid. I have the same problem with mine. I guess thats what the problem is. At first, it would go on and off when I opened the trunk, but now it just doesnt turn on...I am replacing my latch with a power latch anyway, so i'll let you know if that fixes the problem. Later
Old Jun 30, 2001 | 12:55 PM
Speebs's Avatar
I aim to misbehave.
4th gen...
it's a 95 GXE
Old Jun 30, 2001 | 08:44 PM
jashick's Avatar
That's why I asked if other lights were working
Old Jul 2, 2001 | 03:07 PM
Speebs's Avatar
I aim to misbehave.
what am I looking for on the latch? Things seem to move fine, but the light still ain't workin'.
Old Jul 2, 2001 | 07:56 PM
Botos's Avatar
Related questions
I blew this whole circuit hooking up some neon this weekend, which prompts the following questions:
- Which fuse is this on? My interior dome and map lights are also out.
- Which of the trunk light contacts is the positive one? (I know, I know, use a multimeter; but mine's dead.)
Old Jul 2, 2001 | 10:24 PM
DaBoxSE's Avatar
I asked myself that same question...I looked at the latch and it seemed fine, but I figure I'll replace it anyway.
Old Jul 3, 2001 | 09:13 AM
jashick's Avatar
Dunno about the 4th gen, but on the 5th gen, in the latch area (not the actual latch itself), there's a rectangular switch that activates or deactivates depending on whether the trunk is open or closed. Same concept as the doors turning on/off the interior.
Botos, as far as trunk light contacts are concerned,
I would assume the solid black wire is ground...
but like said, verify with multimeter.
REDinLV
Aug 15, 2024 12:30 AM
mrgooch
Sep 21, 2015 08:43 PM
lux97Max
Sep 14, 2015 07:07 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
