How pain in the butt to install alarm system yourself?
A basic keyless entry system is pretty easy. Assuming you can figure out how to run wires into the driver door for lock and unlock, its not bad. An alarm system, or remote start, or most other extras, Id recommend leaving it to a professional.
In general, an alarm is a fair bit more complex to install than stereo equipment. Remote start and window modules can be especially difficult. I highly recommend using a certified shop because you can f*ck up alot without realizing it.
its pretty involved. you also need stuff tools like a test light, tach tester, etc to get r done if its any other car but the ones (max's) on here that have all the lines pointed out to you..
Took me a few days to put in an alarm remote start, just make sure you have multimeter and test everything. Overall not too hard. I would normally pay to get it installed but last two alarm sytems I have had installed at pro shops were hack jobs. Hell I did a better job than them...
I just did one on my womans max. It was the first import that i ever installed on. Ive always done them on my GM's but regardless, with the systems out now and days, you should have some kind of knowledge with electronics and basic theorys of relays and diodes. The Max wasnt bad at all. I think i spent most of the time looming up the wiring and creating an appearance that looked stock so it would be harder to identify. Should you decide to attempt it, i strongly recommend you get some help from someone who has done this before and ask questions if you unsure about anything.
Originally Posted by Pearl96Max
I talk more than I work, FYI
Originally Posted by 97maxhunter
Is there anthing that will work with the stock keyless entry? Maybe ad-on to the stock
MaximaDrvr
Aug 19, 2015 08:20 PM
