aftermarket stereo will not turn on
Old Nov 22, 2006 | 08:05 PM
machinehead131's Avatar
hey guys, today i attempted to install an ipod controller so i could play my ipod through my deck. pulled out my deck and everything and turned the key to see if it worked and it didnt but the deck still turned on. I fiddled with some things making sure everything was connected and tried again and my deck will not even turn on. The clock is out as well. I have check all the audio speaker fuses and have not found a blown fuse. Something tells me it may be bigger than that because the clock is out now. Any ideas?
BTW it is a 2003
thanks
Old Nov 22, 2006 | 08:09 PM
kpr10is's Avatar
How did you go about checking fuses?
Im guessing your reply will be you pulled out a couple and looked at em.
Grab a multimeter or test light, theyre as cheap as $10 at walmart, and test both sides of every fuse. One is blown somewhere...things like that dont just stop working, thats what fuses are there for.
Old Nov 22, 2006 | 08:22 PM
ok, do u think that the clock and the stereo are fused together.... i have a multi meter ill test them friday.
any other opinions?
thanks kpr10is
Old Nov 23, 2006 | 06:18 AM
babymac's Avatar
BOOST 4 LIFE!
Its definitely a fuse check the all not just the audio or bose if you have it
Old Nov 23, 2006 | 11:38 PM
gangsta_max's Avatar
any other opinions?
thanks kpr10is
MOS DEF... CHECK YOUR FUSES.
catalinvint
Sep 16, 2015 07:48 PM
A32goldylocks
Sep 16, 2015 01:33 PM
LtLeary
Sep 14, 2015 12:33 PM
EdRomo86
Sep 12, 2015 07:49 PM
