removing factory stereo in 2001 GXE
Old Jul 3, 2001 | 12:10 PM
j2chan's Avatar
i have removed the cover around the shifter and the 2 screws in the bottom that hold down the air conditioner controls.. i just cant get the thing out! i tried pulling at the vent, but it wont come out. it looks like the vents and the part that holds the stereo is connected. I have the cassette player, so it's not the premium AM/FM/TAPE/CD unit. Please help... thanks in advance.
Old Jul 3, 2001 | 01:27 PM
jashick's Avatar
The vent (above the stereo) and stereo are not connected.
The vent assembly is a bit tough to get out... lift up and pull straight out. After you remove the vent assembly, you should see 2 screws that hold the top of the stereo.
Old Jul 3, 2001 | 01:47 PM
maximadave's Avatar
detailerdaveb@gmail.com
just finesse it a wee bit
Old Jul 3, 2001 | 02:10 PM
j2chan's Avatar
so it's just the front trim/molding around the cassette player and the storage pocket that's attached to the vent assembly?
Old Jul 3, 2001 | 03:49 PM
jashick's Avatar
Remove the ashtray and screw.
Remove trim around shifter.
remove vent assembly above stereo.
You'll be left with the radio/trim/storage pocket.
Remove 4 screws (2 above and 2 below)
The Radio assembly should slide out enough
so you can reach the connectors in the back
Old Jul 3, 2001 | 04:08 PM
j2chan's Avatar
the vent isnt budging...
i used to have a 2000 maxima gxe with the premium sound, and the vent came out easily, but for some reason, this 2001 with just the cassette is different...it wont come out no matter how much i yank at it. are you positive that the design is identical?
Old Jul 6, 2001 | 09:22 AM
jashick's Avatar
Re: the vent isnt budging...
So were you able to yank your stereo out?
I have a 2000 SE with bose... so I can't be sure
if the 2k and the 2k1 are identical... though
I've been told that overall design hasn't changed.
Old Jul 6, 2001 | 11:21 AM
j2chan's Avatar
Re: Re: the vent isnt budging...
i finally got it out after a lot of huffing and puffing.. felt like i broke something on the vent assembly, but it seems okay. looks like on the crappy gxe model without cd player, the front fascia/trim is attached to the vent assembly. the rest seems the same. thanks for all the help.
Mar 12, 2020 12:06 AM
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
QueensMAX
Sep 15, 2015 04:14 AM
mikebla
Sep 3, 2015 05:37 PM
