Subs
Old Jan 12, 2007 | 06:36 PM
Emaxxima's Avatar
Subs
Can you hook subs to a stock headunit
Old Jan 12, 2007 | 08:25 PM
now gs's Avatar
yes, but you will need a level converter.
Old Jan 12, 2007 | 09:30 PM
zero2sixtyZ's Avatar
You embarrass me.
Do you have a BOSE headunit?
Old Jan 13, 2007 | 06:42 AM
nismos14's Avatar
§è~® f®ÈÄk
GXE = no bose.
Amps.
Old Jan 13, 2007 | 04:25 PM
MR.Large's Avatar
A level controller??? Even an aftermarket will not output more then 17watt RMS at 4 Ohm because of the internal voltage conversion. So the answer is NO. BAD IDEA and factory are usually even much less. You can always get a good amp with a High line lever and auto turn on to hook up to your factory radio.
What you looking at running?
Old Jan 13, 2007 | 04:38 PM
Pearl96Max's Avatar
I tend to get a bit irritable
If your referring to directly connecting... I would highly suggest not doing it. If you mean with an amp..yes and its very simple.
Old Jan 13, 2007 | 05:23 PM
nismos14's Avatar
§è~® f®ÈÄk
I think he means a LOC and he would need one if using an OEM deck, unless its a Blose.
Old Jan 14, 2007 | 03:46 PM
Hexon's Avatar
I ran my subs with the stock non-bose hu for almost a year, and I thought it sounded good. I used an amp though. Mine popped really loud whenever I turned off my radio or cd player, however. But besides that and the lack of control, using a LOC, amp, and subs worked well for my budget. Unless you turn the gain down on the sub's amp, it might overpower your stock speakers. So you got to worry about that too.
Old Jan 14, 2007 | 06:45 PM
brynm's Avatar
use an amp, and a line out convertor they can be had pretty cheap, or you can pick up an amp that has speaker level inputs life the JBL BP series. Then you could just tap into the speaker wires and I believe they have an auto turn on.
Redfox
Sep 28, 2015 10:41 AM
Taino14
Sep 24, 2015 02:51 PM
ballerchris510
Sep 23, 2015 08:46 PM
Car Addict
Audio/Video/Electronics
Aug 27, 2015 09:01 AM
