*Pics* Speakers and Headunit in 4th Gen
Old Jan 19, 2007 | 06:40 PM
  #41
matrix11229's Avatar
I bought Premier Deh-P580MP unit, got Metra antenna adaptor and wiring harness 70-7550 from BestBuy.
But the Spacer/tray that they gave me is too wide and it doesn't fit. I'm looking for it everywhere (Autozone & Strauss don't have a normal tray without bulky frame that sticks out.
I'm gonna look in Circuit city.
Old Jan 19, 2007 | 07:13 PM
  #42
andrei3333's Avatar
look dude, u r not supposed to see the metal behind the deck. unless u put it in and took a picture just to see what it WILL look like, thats another story, but u r supposed to have that deck put into the plastic housing that gives u a storage area underneath the deck, and only THEN install it into the dash
Old Jan 20, 2007 | 05:05 AM
  #43
erty67's Avatar
Decal Specialist
Speakers don't have "ohms". It's called an impedance. Ohms is the measurement for impedance. You should check your radio's owners manual to see that the output is rated for. (probably 4-8 ohms) Then if you can't find out that the speakers are rated for, put a multimeter across the two leads on the speaker and see that the ohm measurement is. It should be pretty close to the actual impedance of that speaker. If it's under the radio's spec, you could damage the radio by connecting those speaker to it. Once it gets under the recommended impedance, the radio starts to see it like a short and we all know a short is bad! As long as it as the same ohm impedance rating or higher, it should be ok. Hope this helps.
Old Jan 21, 2007 | 12:15 PM
  #44
Swazey's Avatar
you wont blow ur components running them off the aftermarket headunit. you should deff get a 2 or 4 channel amp to power the components tho, otherwise its kind of a waste because the speakers wont function at their full potential with just the power from the headunit. if you get an amp for the components, then you have to be careful as to not push too much power to them. otherwise you will blow them
Old Jan 22, 2007 | 08:51 AM
  #45
markd248's Avatar
Originally Posted by Chris Z
Me too, actually lol...
post whoring!!
if you scroll up im pretty sure you will see pictures of an installed headunit, i can post pictures of speakers for you but i didnt replace them so they are stock. enjoy your thread and pm privileges.
Old Jan 22, 2007 | 10:29 AM
  #46
1996blackmax's Avatar
Parag is right... I though about doing that with my Eclipse units, and it just seemed that there would be an issue when the face would fold down (especially with the CD7000).
Old Jan 22, 2007 | 11:20 AM
  #47
phenryiv1's Avatar
Mod her. Ate her.
Originally Posted by 2da mizzax
all factory maxima headunits are double din. Bose or not.
Some GXE models had only a single-DIN tape deck/AMFM radio combo.
Old Jan 22, 2007 | 11:41 AM
  #48
JacksMax's Avatar
Originally Posted by ThurzNite
I think walmart has the best price on the dash kit
http://walmart.scosche-cars.com/prod...ductID=1863070
Even has the full size pocket. Plus they carry the universal nissan wire harness too.
Jae
I bought both of these from WM, they were great, and the harness helps to get all the wiring right too.
Old Jan 22, 2007 | 08:14 PM
  #49
I yanked the Bose out the first chance I got on my 5th gen . On my 4th & 3rd gen, I did the same, but they were both non-Bose setups.
To tell you the truth, the Bose system sounded ok...not great, but ok. This ofcourse was at low listening levels. Anything more and the system was being over extended.
Old Jan 25, 2007 | 03:16 PM
  #50
These pics taken with a cell phone camera , I'll post better pics soon.
I used the metra dash tray kit from Circuit City.
Old Jan 25, 2007 | 06:16 PM
  #51
markd248's Avatar
wheres the face plate??
the dash kit looks very nice and flush, i just ordered one so ill have one by next week and a finished dash set up.
Old Jan 25, 2007 | 06:51 PM
  #52
Grand_hustle17's Avatar
yo dude your getting a lil too technical, just get new speakers, that headunit would blow the bose speakers if u had the bose system, factory speakers aint nothin but like 35Watt speakers.... a pioneer, kenwood, alpine, or rockford speakers would be recommended (i work at best buy)
Old Jan 25, 2007 | 06:53 PM
  #53
nismos14's Avatar
§è~® f®ÈÄk
WRONG. Metra 70-7551, safely and easily run the bose speakers with an aftermarket HU.
Time for a new job?
Old Jan 25, 2007 | 07:06 PM
  #54
nismos14's Avatar
§è~® f®ÈÄk
I did the same in the max and alti, both bose equipped
Old Jan 25, 2007 | 07:36 PM
  #55
Time for a new job?
obviously you dont have any comparison skills ... that metra thing doesnt sound better with regular factory speakers than a good after market speaker with any Amp... the bose in the maxima' sound EXACTLY like the infinity's in a chrysler LHS and i've heard both, its not the best yo... why you think when people (like me) upgrade their sound system they go with after market speaker... look at the material that the non bose speakers are made of and look at an aftermarket... it's a night and day difference so, dont tell me to get a new job... how about you start looking for a job
Old Jan 25, 2007 | 07:46 PM
  #56
nismos14's Avatar
§è~® f®ÈÄk
I've done multiple installs with that harness, and always the sound output has been MUCH better quality than the factory alone. Each HU I've installed though, has had high voltage outputs, without that I agree that its probably only slightly better or equal to oem, but with alot more functionality in most cases.
I already have a job
Oh and the comparison here isn't between the aftermarket amp vs bose. That is a whole new ball game. You said nothing about that in your OP. You were wrong about the HU blowing the BOSE, it won't do any harm to them. And as far as speaker recommendations, what about Rainbow, DLS, Hertz, Dynaudio, HAT, Morel... etc. etc.
Old Mar 4, 2007 | 09:13 PM
  #57
Pearl96Max's Avatar
I tend to get a bit irritable
Unfortunately your so far off and dont even know it.
BTW OEM speakers are paper coned a commodity many audiophiles pay big bucks for. Too bad your lost in the hype of cool looking cones at Best Buy to know that. I think you should carefully evaluate your statements and facts before touching the keyboard.
and yes, I do like old funny threads like this one.
Old Mar 4, 2007 | 09:39 PM
  #58
ZaxWhite97Max's Avatar
Wow. No the paper coned suck. I put in a new HU and blew the crap outta the paper coned ones. Easily. (although I was trying) because I was smart enough to just buy new speakers along with the new HU. It didn't take to much time eaither the OEM speakers on the non-bose is what I had and they were in fairly good shape. I popped in the new HU and drove around for a good hour = they gone. ripped all of them all the way around. I should have taken a picture. So Idk what your talking about. maybe I mis understood but paper conned is the suckage. Cool Looking Cones at best buy FTW!
And yeah thanks for opening up teh thread of elite gayness. where he probably already has his new HU in and has blown the speakers and replaced them by now -_-
Old Mar 4, 2007 | 09:43 PM
  #59
Pearl96Max's Avatar
I never said the OEM paper coned drivers, but paper cones in general WILL give the most natural reproduction. Your still young, you'll learn in time.
Your sarcasm is not needed or welcomed.
Old Mar 4, 2007 | 09:55 PM
  #60
andrei3333's Avatar
Paper is the choice of audiophiles alike, but it is not the best choice for car speakers though. At home, speakers are not subjected to such temperature extremes as car speakers are. A car can go anywhere from -30C to +40C where as the temperature is relatively more stable inside a house. Thus paper speakers dry out very fast in a car and easily rip and pop. Also, the rubber surround on a speaker dries out and rips as u abuse it more and more.
Thus the need for plastic based materials in todays car speakers. Plastic does not loose its properties in the same way a paper cone would when subjected to extreme temperature changes. Plastic based cones are also used because of their rigidity, something paper cannot match. As you increase the volume the cone approaches its excursion limit and begins to break up. This Excursion limit is a lot higher for a plastic cone. In other simple terms plastic cones last longer but sound worse. This may be argued by some that say: "Well I can blast my speakers THIS loud". That is exactly the problem with that statement. It's all about quality VS quantity of sound. Paper speakers are more sensitive than heavier plastic speakers are. At 1w of power 1m away from the cone (also called sensitivity) a plastic speaker may in fact be louder than a paper speaker is, but the bandwidth of that same plastic speaker will never be as wide as that of a paper one. This means that although a plastic cone moves more air, it does so at a limited bandwidth, where as a paper cone has a wider bandwidth of frequencies that it can reproduce more effectively. Thats where quality comes in, paper speakers reproduce the vocal range to stunning perfection. Something plastic has yet to catch up to.
So for the sake of ZaxWhite97Max, You blew the paper speakers because you blasted them with base. something those little 6.5" speakers were not designed to do. Why do you think all the new HU's harry 180w/4 or more amplifiers? because they were designed to push those new plastic speakers which are less efficient and need more power to move the same amount of air as compared to a paper coned speaker.
Old Mar 4, 2007 | 10:14 PM
  #61
Pearl96Max's Avatar
Generally correct, but also as you stated..quality over quantity. In this day and age paper cones from reputable manufacturers will last years to come and sound as good as the day they were originally bought.This is of course when treated properly and not misused regardless of ambient temps and the likes.
Old Mar 4, 2007 | 10:30 PM
  #62
andrei3333's Avatar
I completely agree. My main JBL system at home is made of a hybrid design that incorporates a paper cone treated with Polymer mixed plastic. The cone is reinforced but still gives that sweet paper sound. The tweeters are all titanium of course no silk here.
I can't believe what some companies go through to sell their speakers. Take sony for example and their XSV1642A XPLOD speaker. A 4-way design? are you kidding me? Those tiny toy tweeters maybe will produce a sqeal, but a sharp, high guitar note -- forget about it. An effective tweeter is in the 0.5" to 1.5" size no more no less. I think maybe audiophiles will remember BO$E and their pathetic sounding 2" tweeters in their acoustimas series of speakers.
Those things were confused themselves whether they were mid-ranges or tweeters! HAH
Old Mar 4, 2007 | 10:45 PM
  #63
Pearl96Max's Avatar
You mean the Sonys are no good? But Best buy sells em and they look so cool.
please note the sarcasm.
Old Mar 5, 2007 | 04:56 AM
  #64
nismos14's Avatar
§è~® f®ÈÄk
Wow this thread turned into some sweetness lol
MAXSE5SPD
Sep 17, 2022 04:00 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
220k+ A32
Sep 11, 2015 02:18 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
