Poor FM reception while car is on
Old Jan 19, 2007 | 04:17 PM
jif718's Avatar
I'm having static on all FM stations while the car is on. I have a JVC aftermarket receiver and I thought adding a powered antenna would help so I purchased http://www.crutchfield.com/S-3Z0yBQG...search=antenna. Static pretty much stayed the same. The weird thing is my reception is static free when the car is off. What could be the problem? 2000 GXE
Old Jan 19, 2007 | 08:37 PM
arkainshadow's Avatar
well if its a 5th gen, then you have to atach the factory radio amp to either a power source. i used my amp on because my head unit doesnt have antena on. it sounded good but got a little static. after added a few amps to the system it got worse, so i put it to the 12 volt that turns on the head unit. works perfect now. when i first put the hu in i didnt know about the factory fm amp. you could get some stations when the car was off but as soon as it moved it was over. probably same issue.
Old Jan 20, 2007 | 04:36 AM
jif718's Avatar
I have a GXE (No Bose) so I dont have the wire for AMP if thats what you meant. Do you mean I have to connect the "G/W (ANTENNA)" wire to the "PU" or "Y" positive signal?
Thanks!
Old Jan 20, 2007 | 07:28 AM
ya all 5th gens have an fm amplifier built into the car. search for oem antena amplifier in the how-to section of 5th gen. you'll find the color codes and what you need to do.
Old Jan 25, 2007 | 04:46 AM
jif718's Avatar
fixed. thanks everyone... connected the green and white antenna wire to +12V. Still a bit of static, but I think thats because Ive got 3 other things running from that one +12 wire
Old Jan 26, 2007 | 04:17 PM
maximo-SE's Avatar
man i have the same problem. will also try this out.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
Balkins
Aug 12, 2015 06:39 AM
