Wiring these Hertz...(Don, maybe...?) (:
Man, these have me STUMPED...I am about to hook them up, and the instructions just confuse me. With these inline crossovers, do I wire them up in parallel to each channel of the amp? Because the directions show these inlines AND dedicated standalone crossovers...(See steps 12 & 13 in the directions- which refer to the 163 S, not the 165 S, but there is no reference to the 165, specifically). Then, the instructions talk about how to build your own x-overs for the systems on the next few pages, and that the inline x-overs are only fo ruse if these serve as center channel. I don't really understand...
Let me know what you think. If all that I have to do is wire them up in parallel, then I am fine, but the directions say that I need to go active or use a standalone passive box for each channel.
Originally Posted by nismos14
Pat, just wire them in parallel. You will be fine. The tweeters have an inline passive crossover. Mids should be hp'ed off the amp.
But uh..... maybe wait for teh Don to chime in too
This was what I was trying to confirm when I opened the instructions, and they have NO wiring diagrams that have anything LIKE that (as far as I can tell). ALL of the diagrams use active x-oves or standalone passives.
Thats what I would do, esp with both having in-line crossovers.
With the directions not specifying, I am not doing SQUAT until Don looks them over!
Link to owner's manual...
http://www.hertzaudiovideo.com/default_en.htm
Line= Energy, Category= Enregy System, Product= ESK 165S
Thanks...
Thanks...
Don, does hertz have 3 way setups wih dual woofers? I see that in their manual however it's a pita to navigate their site and go through every comp set they have to figure it out
In the .pdf it shows 2 woofers 1 mid and 1 tweeter.
Originally Posted by Pearl96Max
wire em in parallel and reap the benefits of a 2Ohm load for a bit more headroom.
I may experiemnt with co-axial mounting of the tweets in the doors...or maybe using the kicks for the tweets...
Is there an OEM location for tweeter mounting?
Btw, did the set come with multiple resistor values?
Yup it does, but assuming that the resistor values in there match what is listed on the pdf, you're good to go. Wire'em up (in parallel) and go
.BTW- I don't know your actual name. Que es?
Parag... if you remember s/n Kevin on here, thats my brother.
The Frye
Sep 2, 2021 11:03 AM
dvcamp
Sep 18, 2015 10:17 AM
