installing directed alarm/remotestart on 5 spd?
Old Feb 19, 2007 | 12:10 PM
  #41
maxima985spd
i was with dcman and it is the correct wire. im mad because im up at school this week and he cant check it until this weekend. maybe the joint is bad down on the green and white wire. and it says that the hood is open when i lock it. i think is the reason it wont start.
but whats messed up is that last night the car would start for .5 seconds. it wouldnt fully turn over.
whats going on DON??????????
Old Feb 19, 2007 | 12:28 PM
  #42
Pearl96Max's Avatar
I tend to get a bit irritable
So that I understand are we talking about one single car here or both of you having the same issues?
As for the hood, disconnect that wire and see what it does then.
Old Feb 19, 2007 | 01:20 PM
  #43
DcMaN's Avatar
no, its the same car my friend is just being dumb, lets just put his stupidty to the side for now don lol. I think it may actually be the hoodpin causing the problem some how, however the remote start was working through the nss wire untill we hooked up the hoodpin. But why would the diagnostics say the NSS wire is at fault and not the hoodpin?
Old Feb 19, 2007 | 01:50 PM
  #44
Pearl96Max's Avatar
Disconnect the hood pin and see what happens.
Also how is the NSS wired up? Looped through the switch to the small Black/White wire?
NSS > Switch > Black/White?
Old Feb 19, 2007 | 03:21 PM
  #45
maxima985spd
it's the same car. stupidity...im not the one with the bad solder. hahahaha
Old Feb 19, 2007 | 04:24 PM
  #46
maxima985spd
okay i unplugged the hood pin connector in the engine bay then reconnected it. i doesnt say the hood is open at all anymore. so that problem seems like it's gone. but now when i start the car with the remote it turns on for half a second and shuts off like it doesn't turn over fully.
this is soooo weird
Old Feb 19, 2007 | 04:41 PM
  #47
mendon99's Avatar
tastey wheat
ignition turns on then shuts off, or it trys to crank?
could be seeing feedback from the brake. unplug the brake wire and see if it continues.
Old Feb 19, 2007 | 04:48 PM
  #48
maxima985spd
ignition turns on and off real quick it cranks and it will start but right after it starts it shuts off.
okay i guess the hood pin isnt good because if i drive the car then lock it to go into a store it says the hood is open. WTF is going on????
ill let Rob mess with the wires under the dash board. i think the brake wire is a biiyotch to get at
  #49
DcMaN's Avatar
will check all the things that could cause a shutdown, however the diagnostics say that its the neutral safety wire. The nss is hooked up black and white from brain directly to NSS. It was working i tried it for like 3-4 times it worked great then i continued to hook up the siren, and the hoodpin and then it stopped working.
Old Feb 19, 2007 | 04:53 PM
  #50
maxima985spd
werd up wtf is it this is going to be a cold week hahaha
Old Feb 19, 2007 | 04:55 PM
  #51
Pearl96Max's Avatar
Like I said disconnect the hood pin before proceeding any further.
Also the brake wire is Super easy, especially if it was grabbed at the kick area.
Old Feb 19, 2007 | 05:17 PM
  #52
maxima985spd
the hood pin is disconnected and the remote still says the hood is open when i lock the doors. how do you wire up the hood pin because this is my second viper alarm (second car) with a malfunctioning hood pin. we have it hooked by one wire going to the yellow wire on the hood pin. is that right? Don how do you wire up the hood pin?
Old Feb 19, 2007 | 05:32 PM
  #53
maxima985spd
i cut the hood pin wire and it starts now and everything fully functions
NOW HOW DO I WIRE UP THE HOOD PIN CORRECTLY???
Old Feb 19, 2007 | 05:48 PM
  #54
maxima985spd
ok it's back to the same problem now. if i drive it and then park it in nuetral, arm it, and try to start it, it wont work
now it works maybe i have to wait a couple seceonds
Old Feb 19, 2007 | 05:50 PM
  #55
maxima985spd
how do you guys hook up the hood pin?
Old Feb 19, 2007 | 06:39 PM
  #56
Pearl96Max's Avatar
Ok first you need to relaxe, posting every couple minutes will get you absolutely nowhere.
Personally I dont like nor use hodpins due to their high failure rate. But if you insist...its Yellow/Black at the BCM or go directly to the pin itself. Small grey wire off the unit, but these things you should know already since you said you had it hooked up.
Old Feb 19, 2007 | 06:54 PM
  #57
DcMaN's Avatar
thats exactly what i did, don i took the gray wire and ran it out to the hood and connected it right to the hood pin with the color you said. So maybe he has a bad hoodpin ? I told him to let me install the one that came with the viper.Oh and apparenty don the 5900 ssts. Dont default double pulse on. Didnt the 791xv have double pulse on unlock as default ?
Old Feb 19, 2007 | 07:02 PM
  #58
Pearl96Max's Avatar
Dunno why it would be a problem then unless A: Its grounded out somewhere B: The hoodpin itself is faulty.
No sir, none come with double pulse default.
Possibly a faulty unit? Where did it come from?
Old Feb 19, 2007 | 07:27 PM
  #59
DcMaN's Avatar
im not sure where he got it from. I dont ask questions i just install. Lol however it did have a bad lock and unlock harness which sucked. Took a bit of time to figure that out. But otherthan that everything worked out ok. Ill try swapping hoodpins see whats going on.
Old Feb 19, 2007 | 07:30 PM
  #60
Pearl96Max's Avatar
Keep me posted. Also see if you find where he got it from. I have a listing somewhere of all the counterfeit dealers.
Old Feb 19, 2007 | 07:31 PM
  #61
maxima985spd
I ordered it from Sonic Electronix or some company like that. Sorry for posting ever minute. I was just getting frustrated.
How can I test out the hood pin?
Old Feb 19, 2007 | 07:35 PM
  #62
Pearl96Max's Avatar
Hood pin works by ground. If its saying its open, then its either grounded somewhere or its a faulty unit.
Unfortunately if its the unit, youll need a lot of luck getting a replacement from them.
Old Feb 19, 2007 | 07:53 PM
  #63
mendon99's Avatar
tastey wheat
holy crap, f*ck hoodpins, just cut the damn wire off. theyre so useless, put the thing in valet if someone needs to work under the hood, and they ALWAYS FAILL
Old Feb 19, 2007 | 08:45 PM
  #64
DcMaN's Avatar
well what about if some one opens the hood of the car the alarm wont go off, allthough the factory alarm will still trigger atleast it should. So i figured it out why it doesnt start sometimes. There is a delay for some reason you ahve to wait about 15-20 seconds before the remote start will be activated the computer, must not check the Neutral safety wire untill all of the elctronics become idle(ie not running). Maybe this should be stickied in remote start forum so no one has to ask again .
Old Feb 19, 2007 | 08:57 PM
  #65
Pearl96Max's Avatar
The shcok sensor will surely set it off. Ever try to open a hood without entry to the vehicle? Its not easy and surely takes some effort and impact.
Thats Very odd, all the cars Ive done never had any 'delay'.
Old Feb 19, 2007 | 10:29 PM
  #66
DcMaN's Avatar
me either don, ive never encountered this delay, but maybe its because its the new 5900 sst model maybe the remote start sequence is a little different? I'm not really sure but im just glad it works.
Old Feb 20, 2007 | 04:39 AM
  #67
Pearl96Max's Avatar
The confirmation chirps on the remote are definately delayed, but RS should still start in the normal time amount.
Old Feb 20, 2007 | 09:58 AM
  #68
maxima985spd
it's so weird!!!!!!!!!!!!!!!!
Old Jun 18, 2007 | 06:31 AM
  #69
DcMaN's Avatar
btw it turns out the guy i did it for had a bad hoodpin... causing it to not start at certain times. While this thread is up, don the NSS wire for a 2003 6 spd maxima is still green/white correct ? I found a green/white wire (The only green/white wire) in that whole harness, it is located on the left side of the ecu plug
Old Jun 18, 2007 | 06:53 AM
  #70
Pearl96Max's Avatar
Thats correct, but Ive never gotten it at the ECU. I always went under the hood.
Old Jun 18, 2007 | 08:55 PM
  #71
kpr10is's Avatar
Should be Pin 44, Ive gotten it at the ECU.
MAXSE5SPD
Sep 17, 2022 04:00 AM
220k+ A32
Sep 11, 2015 02:18 AM
flu2000
Sep 8, 2015 02:23 PM
