2k2 Max audio need help
Old Feb 28, 2007 | 08:02 PM
aptgrk's Avatar
Today I set out to add dynamat to the front speakers. When I removed the door panels, I found that the speaker were aftermarket. Polk 6.5" model xd6510 (4 ohm), and it had a dxSeries Component Crossover that connected to an aftermarket tweeters. I bought my car used and it had the bose h/u with the rear deck subwoofer + amplifier.
Why do the speakers work with a system that was originally bose?
I've had the car for about 8 months now and the speakers haven't had any problems.
Does this mean the speakers have already been rewired...bypassing the bose amplifier?
Or maybe the component crossovers allow compatability?
Also, the FL=blue/white wire FR= brown/white.
Old Mar 2, 2007 | 04:56 AM
aptgrk's Avatar
forget it, I'll just try to follow the wires, or just bypass all of them so I could put in a new amp for the speakers.
Old Mar 2, 2007 | 05:13 AM
nismos14's Avatar
§è~® f®ÈÄk
If the speaker are in alreayd all you have to do is run wires from the new amp to the polks. Seems like they wired them up to the bose amp... if it sounds good to you why change it? If you're looking to upgrade def throw an amp in there maybe some better comps too.
Old Mar 2, 2007 | 10:29 AM
aptgrk's Avatar
It sounds ok, but it definetly needs more volume. I just have too much road noise, and the exhaust that came with the car is pretty loud. I guess all I have to do is unplug the harness going to the bose amp to see if its connected.
Have any suggestions with comp choices at midrange prices (<$250/pair)?
Old Mar 2, 2007 | 10:35 AM
nismos14's Avatar
§è~® f®ÈÄk
ACtually, send a pm to burnurass he has a VERY nice set of comps available!
Old Mar 2, 2007 | 10:38 AM
burnurass's Avatar
Also I might have the trim rings for the speakers so you don't have to buy them....they're a little ghetto but they do the job. I don't have the fine tools that mr. Craftsman ***** DON has.
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
Fbana41
Aug 29, 2016 12:18 PM
