microvison Q's
Old Mar 28, 2007 | 06:06 PM
95turbo gxe's Avatar
microvison Q's
Im wondering How can I hook the microvison screen up to where when I cut the car on it comes on altmaticley? It has three wires one red one black and one orange!
Old Mar 28, 2007 | 09:23 PM
lewtion1's Avatar
red is positive (to battery)
black is ground
orange i believe is to ACC for memory of settings
I installed a switch in one of the rocker panels on the right side of my steering wheel. (one is a dimmer switch the other is a dummy panel). basically i hooked it up so that i can turn the screen off when I want, but mine boots up automatically whenever i turn the key. Since I never need the screen to remember my settings, I don't use the orange wire. My power lead is connected to my clock (always on as long as key is turned) and my ground is inside the firewall to the chassis somewhere.
it's easier to see when the dash is apart than to read on a computer screen. hope this helped a little.....or confused you more....either or, my job here is done!
Old Mar 29, 2007 | 06:36 AM
black is ground
yeah Thats kinda what i thought, but this one only cuts on when you use the remote it wont cut on by it self!
Old Mar 29, 2007 | 06:52 AM
2AZN2DMAX's Avatar
Try just hooking up the power wire without the ground. Usually that works if the monitor is a signal sensiing unit. I have not installed a Microvision TFT but I've hooked up plenty that way and it works, you don't the remote to turn it on. Let me know how it works out.
Oliver
Old Mar 29, 2007 | 08:36 AM
ok Ill try and see!
Old Apr 1, 2007 | 04:22 PM
2AZN2DMAX's Avatar
Did it work?
Old Apr 1, 2007 | 04:40 PM
mendon99's Avatar
tastey wheat
i believe the orange wire is the switch. wire it with the red one if you want the screen to come on with the car.
Old Apr 1, 2007 | 05:01 PM
DukeDuke's Avatar
The Red is the power, black ground and orange illumination. T-tap(or just wire together) the orange and red. Then take it and T-tap off of the red on the HU and it will turn on as the car does. I have mine set that way for now, I hate it. I hardly ever use the screen, so it is just killing the life of it for me now. But if that is the way you want it, that is how you do it. Good luck.
jattdemax
Jun 7, 2007 09:52 PM
95turbo gxe
Mar 29, 2007 11:21 AM
Black Maxima
Apr 16, 2006 08:13 PM
gen4maxse
Nov 16, 2005 05:37 PM
baracus
Dec 14, 2004 03:01 PM
