Jensen VM9312
Old Apr 17, 2007 | 10:17 AM
PaulyPoTz's Avatar
Jensen VM9312
Anyone ever install a Jensen Vm9312?....if so how did you bypass the ebrake feature...i grounded the wire and it doesnt work..any infor would be of great use..thnx
Old Apr 17, 2007 | 10:47 AM
JEXTEL's Avatar
I have the 9311ts and you cant just ground the ebrake wire> All you have to do is buy a $2 switch and ground one end of it and connect the other end of it to the radio then whenever you want to watch a movie flip the switch off for 5 seconds then turn it on and it should come on. I have the full tut. I cant find it right now but its in my favorties at home
Old Apr 17, 2007 | 04:13 PM
PaulyPoTz's Avatar
yes that was what i was told...i just came back from the shop and he did just that...still didnt work...he said he has had the same H/u and installed it and it worked...i have a feeling my headunit is defective and i will be returning it...btw NEVER order anything from ikesound.com
Old Apr 17, 2007 | 04:24 PM
kpr10is's Avatar
Ordering Jensen was just as bad.
Old Apr 17, 2007 | 08:53 PM
PaulyPoTz's Avatar
theres nothing wrong with Jensen.... i like the features and for the price you cant go wrong
Old Apr 17, 2007 | 11:22 PM
kpr10is's Avatar
Believe me. Ive dealt with plenty of cheap @ss customers who come in and buy them, which therefore Im forced to install them. With the amount of them that come back with all kinds of problems, I can 110% say that theres PLENTY wrong with Jensen, and Id much rather run a stock headunit.
But whatever floats your boat.
Old Apr 18, 2007 | 09:05 PM
htdsngup's Avatar
Yah well im pretty broke and in college so im holding off on a $2,000 eclipse HU for now.
I installed one myself and just had to ground BOTH wires to the chasis. If ur HU works, then i guess its grounded enough. Make sure u have both ground wires installed.
And the bypass code is as follows so u dont need to use the switch if u dont want:
Goto Am/Fm mode
press "setup" on remote
press "543210"
on the new menu, tough the "hammer/screwdriver" button on the upper left
And then choose "Brake bypass" to "ON"
Then hit the "X" on the bottom of screen.
Tell me if it works
Old Apr 19, 2007 | 06:29 AM
bigmike8771's Avatar
the code is:
up, up, down, down, left, right, left, right, b,a select, start.
j/k
Old Apr 19, 2007 | 08:14 AM
PaulyPoTz's Avatar
Goto Am/Fm mode
press "543210"
Tell me if it works
i just uninstalled myunit last night to send it back...i tried the pulse method with the switches and it didnt work...i was told by an install pro that the prk switch wire coming from the unit was probly bad and to return it...............i uninstalled everything last night and went back to stock....today i wake up and for somereason look for an alternate way...i found the exact codes you just gave me...this tv has been a pain in the *** ever since i bought it but i guess i will give it a shot tonite...thnx alot
Old Apr 19, 2007 | 10:17 AM
htdsngup's Avatar
Originally Posted by bigmike8771
the code is:
j/k
Contra!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 19, 2007 | 01:17 PM
slickrick's Avatar
I think that is the only code I remember from a videogame...and what a game it was.
Old Apr 19, 2007 | 01:25 PM
illlojik's Avatar
I C U
Known around the world as the infamous Konami code....
Old Apr 19, 2007 | 10:02 PM
PaulyPoTz's Avatar
[QUOTE=htdsngup]Yah well im pretty broke and in college so im holding off on a $2,000 eclipse HU for now.
Goto Am/Fm mode
press "543210"
Tell me if it works[/QUOT]
Codes worked!!! tv works !! im happy... thnx alot man... i was abiut to return this thing
Old Apr 21, 2007 | 05:28 AM
Batxel's Avatar
blah
the code is:
i miss my nes
Old Apr 21, 2007 | 06:08 PM
im sorry i had to go there.....
Old Apr 28, 2007 | 10:42 PM
NIGHTMAREuki's Avatar
my dad's caravan has 1.5 din jensen HU and its the worst one i have ever seen
just my 0.02
2 tha MAX
Audio/Video/Electronics
Aug 4, 2008 08:02 PM
92SE_Threat
Mar 21, 2003 10:32 AM
2k2.6spd
Jul 22, 2002 07:56 PM
