to anyone thinking of buying cheep rca's
Dont do it. i spent over a month trying to get rid of alt whine in my system. on a whim i swaped out the cheep shielded rca's for a set of twisted. (had 3 pairs of shielded rca's and went down to one high quality twisted) ... no more whine or distortion. so dont cheep out on the rca's.
Meh nuttin wrong with Stinger, in fact I stock the majority of their interconnects. BUT they are a bit overpriced in the price - performance ratio. Riding the wave of the most popular name in the biz.
Believe it or not you can actually use bare wire to run your signal to your amplifier and NOT have the alternator noise heard through your amp. There are several issues as to why you have a wine with a cheap pair verses a high end pair.
1. The most important factor is placement in the vehicle. Most vehicle manufacturers run their power, acc., signal (communication) and battery (for components that do not rely on acc for activation but are turned ON from an independent acc from another module. i.e. radio and power ant.) on the driver side of the vehicle to the rear. Therefore in these cases you MUST run your Amplifier battery and remote wire on the driver side, then your RCA on the passenger side.
2. The theory behind the wine is a magnetic field that is generated as the current flows through the copper, then couples on the shield of the RCA's. The reason why most good RCA's don't allow coupling is due to the shielding (form the source end) is single-end (terminated one side) allowing the coupling to dissipate to ground. [i.e - monster cable are directional] Terminating the shield on both ends will create a ground loop which is basically an antenna for magnetic fields. Well sorta, just do not want get to deep in theory!
3. Twisted pair works on the same theory yet does not allow a complete signal phase to couple, which makes it far more superior to a standard RCA cable.
I'll be upgrading mine shortly with some 300 series Monster Cable RCAs.
Also upgrading my speaker cable with some Stinger 12 gauge. I pray that will eliminate my whine and help SQ.
Also upgrading my speaker cable with some Stinger 12 gauge. I pray that will eliminate my whine and help SQ.Unfortunately it wont improve your SQ. Just fyi - Monster is THE most overrated brand on the US market.
Originally Posted by illlojik
Been using scosche for years. never had a problem with whine
Originally Posted by nishfish871
You mean their really thin wires that you buy from walmart? I use that for the sub amp but gotta upgrade real soon cause i think it is hurting me.
Originally Posted by mattj10
knukonceptz krystal do it for me..
Like the ones pictured here ...
http://www.pearcable.com/sub_audio_cable_quality.htm
Generally .. Stinger or IXOS
http://www.ixos.co.uk/us/where-to-bu...1&ZID=1&CID=31
I dont think they updated their website yet though to reflect the mobile lines. Although alot of my clients have used the Ixotica which is in both home and mobile.
The other is
www.pearcable.com
The other is
www.pearcable.com
