Sealing off sub box
Old May 9, 2007 | 09:52 AM
steves01max's Avatar
Sealing off sub box
I have 2 12" subs in a sealed enclosure. The box has a leak at both sides of the box. What should I do to reseal this and get rid of the air leaks? Should I just use silicon along the side of it or drill nails in it to seal it off? Thanks.
Old May 9, 2007 | 10:18 AM
nismopc's Avatar
I would use wood screws to pull the wood back together, then seal with caulking. If not, your leaks will potentially appear again.
Old May 9, 2007 | 10:36 AM
AscendantMax's Avatar
caulk the corners on the inside.
better yet, build a new box.
Old May 9, 2007 | 11:15 AM
nismopc's Avatar
Oops, sorry I thought the caulk on the inside was common knowledge.
Yea, do what he says...
Old May 9, 2007 | 11:46 AM
nismos14's Avatar
§è~® f®ÈÄk
I think its new box time
Old May 9, 2007 | 11:54 AM
slickrick's Avatar
I knew there was a leak! If you are **** you can take a small piece of sound deadening and put it on all the corners.
Old May 10, 2007 | 06:54 AM
Lol, yeah I found it out after the 2nd amp was put in. I may drill screws into it for now instead of getting a new box and repositioning one of the subs because it's a little raised from when it was put in.
James92SE
142
Jan 2, 2024 09:23 AM
mpbclutch33
Dec 26, 2015 11:11 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
The Wizard
24
Oct 1, 2015 08:47 PM
Sep 27, 2015 08:37 AM
