Look what the mailman brought me.....
$5 e-dollars for anybody who can name it
I'll be using an older RF 250w RMS amp, but I hear it's underrated. Recommended box size is between .25 cu ft to 1 cu ft. I'm thinking somewhere around .75, but am not sure yet. Any thoughts on box size?
Originally Posted by Pearl96Max
Looks like a DIYMA sub. Payme ?
$5 e-dollars sent
I can't wait to throw this thing in a see how it sounds.....
Thoughts on box size?
I tend to get a bit irritable
ding ding ding!
$5 e-dollars sent
$5 e-dollars sent
Paypal addy: MyPearlTPI@aol.com
Try a 1cf, youll be quite pleased.
Originally Posted by AscendantMax
don't remind me...
that cone (in the first pic)...was it dirty or something?
I tried searching the DIYMA forum, but couldn't find anything, so I'll ask here.
I was told there is a break-in procedure for this/any sub. I never did anything like this on my old subs, and was wondering what you guys did for the burn-in/break-in process? Tips?
EDIT- From what I just found, it seems people recommend playing the sub at low volumes for anywhere between 20-50 hours. Is this similar to what you guys have heard?
Umm why would you cry over a comment like:
Those subs actually perform quite well and worth Every penny they cost.
any advantages using an circular magnet array such as that over the conventional slugs? motor strength seems pretty average.
www.diymobileaudio.com
That was a compliment towards them in case it flew over your head....
Sorry, it was a bad joke.....I knew what you were talking about
My best guess is that it will get about 350-400, based on the birth sheet from that amp. As far as I can tell, he wants optimum output from the sub without severely compromising quality.
Nick has selected the speaker package that you recommended to me. I just cheaped out on it.
Different drivers perform differently in different sized enclosures.
My sp12 for instance is meant for a ported box but it sounds phenomenal in a 1.25 cu ft sealed box. Again it's not even recommended to be used sealed.
Some drivers will like less air space some will require a lil more, this is all vs the manufacturer's spec..... Some will sound better with less (generally not the case) and most/many will sound better with larger than recommended enclosures.
Originally Posted by phenryiv1
So Don, it looks like you are saying that he should go with the high-side recommendation as far as enclosure volume. Will that help with musicality or output?
Thanks, guys. I have a 1.25 per side sealed box that I was going to cut in half and give to nick. I can just cut a little more than half off of it and put a new endcap on it.
Nothing beats "free" when it comes to enclosures!
