A good place to mount amps
Old May 24, 2007 | 02:03 PM
Ruthless's Avatar
Ok, i have decided mounting the amp / capacitor to the sub box is the worst idea ever. I want to install it to the car itself, to make sure that the + / - wires NEVER move, therefor, never become disconnected. Then, have your speaker wire run to the box.
Does anyone have theres setup like this?
I was thinking about taking the back seat of my 99 maxima out, then drilling holes in the metal, then mount the amp to the metal (inside the trunk side), then place the seat back. Has anyone done this setup? Also, I am getting a 4 channel amp for my mids and tweets rather then running it off my deck... Should this be placed in the trunk aswell??? Better place to put your 4 channel amp??? or amps period?
Will someone PLEASE reply with a good idea on where to mount 1 (maybe 2) amps + 1 cap to the car NOT to the sub boxes????
(ps, i am not that crafty)
Old May 24, 2007 | 02:19 PM
burnurass's Avatar
what my trunk USED to look like:
Similar to your idea...got a board and wrapped it in carpet. Mounted that to the back seat, then mounted the amp to that board.
My other amp in the trunk:
borrowed the idea from nismos14's 4th gen. All it is is two boards wrapped in carpet then mounted to the trunk.
Old May 24, 2007 | 02:26 PM
Ruthless's Avatar
mm, not bad, can you still get your spare tire out?
Old May 24, 2007 | 02:48 PM
burnurass's Avatar
yep...not easily but it's doable if need be.
Forgot to add this picture
bezel installed
Old May 24, 2007 | 06:39 PM
DcMaN's Avatar
my .02 cents
Old May 24, 2007 | 07:58 PM
nismos14's Avatar
§è~® f®ÈÄk
So how well do you like the paperweight that you have in your trunk?
Old May 25, 2007 | 01:21 AM
julioenr's Avatar
Place for an amp
Well as you stated to place the amp below the seats that's very useful. I actually have two amps placed under each seat (duh). and also a third (mini one hopefully out soon of my car, for a bigger one) below the stereo inside the dash. Personally those three are the best places since you don't really use that space and if you do a good ground on the amp you don't even have to take out the seats. I did my ground for my MTX TC600.1 by putting a 4 awg cable below one bolt that seats the emergency brake. It works just fine. Just connect everything in place then route the cables trough the arm rest (where the emergency brake is ). It will help to take out the cup holder so you can pull/slide cables from there to your stereo and batt + . for me the trunk it isn't a good Idea. I use it for many things once I even put a 6 cylinder engine on it jaja.
The amps I have is MTX tc600.1 and a Diamond Audio 400.4, and the mini one doesnt count jajaj it is a 100 max watt so real samll to power my center speakr
Old May 25, 2007 | 05:33 AM
DcMaN's Avatar
editeeeeeeed
Old May 25, 2007 | 05:38 AM
mendon99's Avatar
tastey wheat
Originally Posted by DcMaN
Nismos14 i hope that wasnt intended for me but if it is then.... Just because you cant afford JL audio doesnt mean you should bash my ****.
bwahahaha
Old May 25, 2007 | 05:53 AM
burnurass's Avatar
Originally Posted by mendon99
bwahahaha
IBTDon
10bans
Old May 25, 2007 | 05:57 AM
nismos14's Avatar
§è~® f®ÈÄk
I was referring to his CAP.
Old May 25, 2007 | 06:12 AM
DcMaN's Avatar
and thats why i said IF you were referring to me if not.... then no harm done
Old May 25, 2007 | 06:24 AM
nismos14's Avatar
§è~® f®ÈÄk
Lol... edited
Old May 25, 2007 | 06:33 AM
Pearl96Max's Avatar
I tend to get a bit irritable
While I can appreciate the devensive standpoint, do you really think "cant afford JL" was the best tactic? Theyre really not pricey and One he has in there now holds nearly the value of two of the slash amps (1000/1 aside)..
To go a bit further One of my amps would equate to three of yours at an SRP level, does that mean it is ok for Me to bash em?
Carry on fellas.
Pearl96Max's Avatar
BTW dont start jumping down my throat, Im just havin a lil fun with you fockers.
Old May 25, 2007 | 06:35 AM
nismos14's Avatar
§è~® f®ÈÄk
YOU FREAKING A)QUT()QU#)%U)!(U#)%(UJ)!(#% lol
Old May 25, 2007 | 07:10 AM
burnurass's Avatar
DON > *
/thread
Old May 25, 2007 | 07:15 AM
Ruthless's Avatar
Under the seat??? Wtf? Where do i put my drugs????? Bad idea... No room for a cap under there either... And you bolted it to the floor??? Sounds like a ***** if a wire comes undone from drunk friends or something.
So, clearly, what you guys are saying is that you all have weak designs? cool design = cant access / dont have spare... but not practicle..
No one has mounted the amps to the back of the seat before?
I thought about the in dash........ too bad how big they make these fockers.
Old May 25, 2007 | 07:19 AM
Ruthless's Avatar
The connectors on your amp look beautiful!!!! What kind of connection is that? Do they all just "click" into place like a phone cord? If so, drool....
Fricken rockford 5002 %#$^$#%^$
Old May 25, 2007 | 07:34 AM
burnurass's Avatar
UM...they are just bare wires. lol. I didn't even use connectors...I just unscrewed the terminals and put the wire in there like all other amps... but thanks for the compliment. NOW IF ONLY MY TRUNK WAS THAT NEAT NOW!!
Old May 25, 2007 | 08:08 AM
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
My solution:
Old May 25, 2007 | 08:47 AM
mendon99's Avatar
tastey wheat
Im thinking he's never seen any amps with the Hex bolts to hold the wires on, just the older style with screw terminals.
Old May 25, 2007 | 09:01 AM
Ruthless's Avatar
Originally Posted by SgtSchulze
My solution:
Holy **** Mcgiver!!! thats the best idea ever!!!
You buy or make that?
Old May 25, 2007 | 09:13 AM
nismos14's Avatar
§è~® f®ÈÄk
ZOMG"Z thats the bestest idea evear.....
Old May 25, 2007 | 09:29 AM
Torgus's Avatar
hmm mount the amps on....
an amp rack!?>!?
mount rack to rear seats.
subs in front
throw on a face plate to block it off and your done...
you can put an amp anywhere you want for what it's worth. some are just better then others...
Old May 25, 2007 | 09:32 AM
nismos14's Avatar
§è~® f®ÈÄk
Word throw the amp on the roof
Old May 25, 2007 | 09:50 AM
Fast1one's Avatar
Mine are both under my seats, industrial Velcro FTW, they are fairly small so they get plenty of breathing room and stay cool, ZED audio made us acoustics.
Even if someone wanted to steal them, its pretty hard to yank then out unless you pull the seat and yank up
Old May 25, 2007 | 09:56 AM
Ruthless's Avatar
sucks i cant really do that idea... arg, i have to go with my back of the seat idea. Ill let you know how things turn out. Could be shady. I got the afternoon off work. Yay. Ill configure something out. I got a 4 hour car ride on monday morning i will need beats for.
Old May 25, 2007 | 10:01 AM
slickrick's Avatar
My amps are mounted under the seats...but my 15 Farad CAP is mounted on my headers to help gain HP and help with exhaust flow.
Old May 25, 2007 | 10:26 AM
Ruthless's Avatar
Normaly I just adjust the Flux Capacitor to gain maximum performence.
Old May 27, 2007 | 03:27 PM
djfrestyl's Avatar
Suspension Yoda
30 posts and not one person has successfully recommended to the OP to DITCH THE CAP ALTOGETHER. You do not need it. Please rid yourself of it.
Just to summarize, to you, the reason mounting an amp to the back of the box is a bad idea is because your box moves around and therefore yanks on your power cables? Here's an idea - secure down your box??
I've got my amp mounted to my box with zero issues, because my box is secured down. If you're looking for an idea for your trunk, here's one:
Oh, and that spare tire board is for sale - see sig
[/shameless plug]
Old May 27, 2007 | 03:30 PM
Pearl96Max's Avatar
Im sooooo tired of typing that, let people learn on their own...
Old May 27, 2007 | 03:31 PM
djfrestyl's Avatar
Suspension Yoda
Bah, I'm in a half-decent mood. Surprised it didn't come out WAY more sarcastic.
Old May 27, 2007 | 03:32 PM
Pearl96Max's Avatar
Unfortunately I couldnt be so niuce. Its been a long day.
Old Jun 4, 2007 | 08:12 AM
Ruthless's Avatar
Why would you assume the cap is useless???
Old Jun 4, 2007 | 09:19 AM
nismos14's Avatar
§è~® f®ÈÄk
We're not assuming that it is, it is.
Old Jun 4, 2007 | 12:38 PM
Ruthless's Avatar
mmm, that would reduce the total amount of connections aswell.... Mmmmm
If my alt dies again imma snap... now that i think about it , it died with the cap attached aswell.
Old Jun 4, 2007 | 01:39 PM
z0dE's Avatar
FIrst off, square boxes are extremely over-rated when it comes to accoustics. You actually lose SPL due to resonance of a box. With that said, form a custom box that will be rounded at the edges and you will actually increase the SPL inside the box with out having to increase box size. Since you are creating a resonant frequency inside the box, look at the type of music you like, do you want superior bass extension or loud impact. If you want the extension look for something with a High Sensitivity and Low Extension Such as the Infinity Kappa Perfects feed those with 100 watts RMS and the right enclosure and it will sound far superior to your Rockfords with 1000 watts in a square box.
Now as far as amp placement. Under the seats are realetively good, except for when you turn the heater on and fry the circuitry with hundred of CFM of hot air hitting it. The size of your amp will largely be based on the Type, efficiency and Wattage. Most of the mainstream amps are bulky mainly due to inefficient designs with added transistors and voltage regulators and larger heat sinks for heat dissapation from the higher wattage.
I personally use Mono amps for every single speaker, yes it costs more but in the long run its easier to diagnose whats wrong and to fix it. Bad places for amps: Engine bay and under seats mainly due to heat dissapation. The best amp placement solution I have seen is the Tray mounted on the top of the trunk. If it is using wire mesh top, bottom and backing, great heat dissapation and also you could lock the tray adding security to the system. Along with boxes that allow for great resonanse at lower frequencies you will have a great sounding form fitting solution.
Old Jun 4, 2007 | 03:26 PM
slickrick's Avatar
without dissecting and proving most of your theories wrong I will touch on one...your claim of using mono amps for every speaker INVALIDATES everything else you said.
Old Jun 4, 2007 | 03:27 PM
djfrestyl's Avatar
Suspension Yoda
Damn, you beat me to it.
