02 HU install misalignment issue
Old Jun 8, 2007 | 09:01 PM
brusk's Avatar
Ok help me out here because I'm confused as F***. I just got back in town and installed my new CD7100 with the "coler matched" (yeah ok) scosche kit. New brackets from DaveB since I had the Navi before. I get everything installed and working no problems and go to add the Vent and scosche plate and realize the HU and pocket are like 3/8 to 1/2 inch too high. There's only the standard bold holes and **** only goes in one way. I don't see how on earth the factory could have messed up my brackets since they are all probably stamped from the same die. Unless I can figure it out I'm going to have to use the black scosche kit I have laying around and that things is even uglier. Any body ever seen this problem hopefully it was something I missed since I havn't pulled it back out to double check things.
Old Jun 9, 2007 | 05:13 PM
WeeZyFellA's Avatar
if you bought the kit it should have had the install instructions with it. you need to drill 3 new holes on each sides of the bracket to lower the hd.
Old Jun 10, 2007 | 08:21 AM
brusk's Avatar
Uh yeah it did say that. What a POS I wouldn't have bought it if I would have known that. Maybe I'm just having a bad day but the holes they have on the template are actually higher than what I have now and it's not explained very good. Since it was only going to be a short term solution untill I buy the 130 vent/trim piece and pocket anyway I used the older scosche piece. It didn't fit the greatest and the black looks like @ss but does the job for now.
JRod28
Dec 29, 2023 09:56 PM
Cotozic
Jun 28, 2017 08:01 PM
Maximeltman
Aug 31, 2015 01:01 PM
stromm
Aug 27, 2015 04:13 PM
kirkhilles
Aug 8, 2015 10:53 AM
