Bose System CD Player
Old Jun 21, 2007 | 08:50 PM
STILLENGLE's Avatar
Whats up guys i have recently experienced a problem with my Bose System when i put a CD in i now get Fadeing in and out when i listen to a cd do you guys know what might be the problem i know i have posted other problems about my car but this is the lastest one. i have a created cd in there i took it out and it worked fine for a day and then all the sudden it started fadding again. this only happens every now and then but now its frequent.
Old Jun 25, 2007 | 07:36 PM
Bose's Avatar
Please help with Bose audio systems
Hi,
I own a Nissan Maxima 1996 with Bose audio systems. Now my Bose Head Unit PN-2083D got a problem. Its power can be turned on. It shows the display, but it DOES NOT produce any volume/sound. I can't listen to the radio and CD. I don't know this problem because the head unit is broken or the amplifiers of all speakers are broken.
So, my questions:
1. Which one is the most possible broken, head unit or the amplifiers?
2. Assuming the head unit is broken and wanting to replace with an after market head unit, what should be done to still use these Bose system's speakers and/or amplifiers?
3. Assuming all amplifiers are gone, what should be done if i wanna use after market speakers? Do i have to replace Bose head unit also if my stereo has this issue?
Thank you
Old Sep 13, 2007 | 06:14 PM
svojs's Avatar
Check the sticky FAQ threads. You should find how to and what needed to install new HU and/or new speakers.
For a 1996 Max, it's time to upgrade a new system. You will not regret.
Mine is 99 with BOSE. The HU showed "CD Err" a month ago, then I knew it's time to get rid of the Bose. Since I do not have much $$ and time, I just bought a new HU with all installation harness/converter/DIN kit from Crutchfield. Though it is still under construction, I believe I will get better sound.
MichMaxFan
Sep 30, 2015 09:18 AM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
