alarm help quick!
Old Jun 28, 2007 | 10:26 AM
GriffinW's Avatar
alarm help quick!
I never post here so this might be a repeat question just phrased differently than someone else. I also used the free search before I made my own thread. Im in the process of installing a Crime guard 533i^4 in my 97' and I cant get this thing to work. I bought the harness for the ignition switch so I know that isnt my problem. I grounded it to the bolt that holds the seat in so the ground should be good enough. The diagram from Crimeguard says that I need a wire the "(-) Door pin switch" and "(+) door pin switch". I used the G/Y wire for the negetive and the LG/R wire for the positive. Now without wiring anything else (parking lights, siren, trunk, etc.) it should work correct?
I need help ASAP.
thanks guys
Old Jun 28, 2007 | 01:39 PM
Snypa's Avatar
did your car come with factory alarm?
Old Jun 28, 2007 | 02:57 PM
GriffinW's Avatar
yes
10 char
Old Jun 29, 2007 | 09:17 AM
GriffinW's Avatar
anybody?....
Old Jun 29, 2007 | 09:45 AM
Pearl96Max's Avatar
I tend to get a bit irritable
What did you connect the + door trigger to? There are no + triggers for doors in the Maxima. Yes it *should* work, but I think your misleading yourself by thinking that there could be nothing wrong with the 'ign harness that you bought'. Have yo inspected and confirmed all the wires on it? Checked that they are correctly located?
Old Jun 29, 2007 | 11:33 AM
GriffinW's Avatar
The positive door trigger is connected to the lightgreen/red wire like it states in my first post. I double checked all the wires going to the ignition harness and they are all fine. The only other wires I have are the two going into the door lock and unlock switch, the ground and the trunk open switch. Do I have to disarm the factory alarm before it will work or something?
Old Jun 29, 2007 | 11:53 AM
Pearl96Max's Avatar
But what Im trying to say is that there are NO + door triggers in your car. Oh and your - is also on the wrong wire.
Old Jun 29, 2007 | 12:01 PM
GriffinW's Avatar
ok well since you know its on the wrong wire, can you tell me the correct wire? I know that you are saying there are no + door triggers, but when the crime guard wiring diagram says to connect a wire to the positive door trigger, what am I supposed to connect it to?
Old Jun 29, 2007 | 12:20 PM
mendon99's Avatar
tastey wheat
the crimegaurd probably gives you the option of a - and a +. you need to use the neg.
Old Jun 29, 2007 | 12:21 PM
Pearl96Max's Avatar
Red/White in the kick panel. Also where you can find Brake/Parking lights and trunk.
Connect it to a postive trigger in a car that has one. Alarms are universal, not all cars are the same.
Old Jun 29, 2007 | 12:35 PM
GriffinW's Avatar
ok so I just took the electrical tape off the thick group of about 30+ wires under the kick panel, now i should wire the negetive door tigger to the red/white stripe, trunk to the pur/yellow, and what color is the parking lights?
Old Jun 29, 2007 | 01:00 PM
Pearl96Max's Avatar
Yes.
Yes. Make sure you use a relay.
Parking lights are Red/Blue IIRC. Brake is Red/Green.
TEST ALL WIRES FIRST
Old Jun 29, 2007 | 02:09 PM
mendon99's Avatar
tastey wheat
do you not have diagrams?
you really should just be taking it to a shop if you're asking these questions. You're gonna blow something..
and parking light positive is actually red/green as well at the steering column.
Old Jun 29, 2007 | 03:09 PM
Pearl96Max's Avatar
I agree.
Red/green at the kick though. WHy go to the column if ya have wires already going to the kick? Saves me a bit of work everytime.
Old Jun 29, 2007 | 04:37 PM
mendon99's Avatar
tastey wheat
well the ignition wires are basically at the column too so, same arguement. but yeah, either way.
Old Jun 29, 2007 | 05:03 PM
Pearl96Max's Avatar
I like grouping and twisting wires, much easier to do without the ribbon cable.
Mar 12, 2020 12:06 AM
NewMax03
Oct 7, 2015 08:27 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
