Amp and Ohm wiring-Help Please
Old Jul 3, 2007 | 06:04 PM
dejahn23's Avatar
I want to hook my amp (Rockford P325.2) up to my front door speakers (Rockford T162C) but heres my problem. I dont know how to know if the ohms match the speakers.
The Amp's Box says I can get 80 X 2 @ 4 Ohms
My Speakers are 4 Ohms
I was looking at the installation pic that came with the Amp and the picture is unclear. it shows that if I use the "+" from the left and "-" from the right I will get 4Ohms. but am I to do the opposite (- from the left and + from right?)with the speaker wire that heads to the other speaker OR do I put both speakers in the SAME slots?
Any websites with pics would help along, but I trust ppl who respond know what they are talking about
THANKS
Old Jul 3, 2007 | 06:17 PM
DcMaN's Avatar
its 4 ohms per channel, since you have a P325.2 (2 channel amp) You would just plug it in as normal, positive to positve and negative to negative. One being your left speaker and the other your right speaker. The figure you were probably reading was the bridged part, if you were to combine both channels, its out put would give you full power @ 4 ohms bridged.
Old Jul 3, 2007 | 06:18 PM
nismopc's Avatar
edit: yea what he said
If you do what you explained, you'd be running a bridged/mono amp to one speaker.
Old Jul 3, 2007 | 11:29 PM
Bollwerk's Avatar
http://www.bcae1.com/
Excellent site that can answer both basic and more complex questions.
Old Jul 4, 2007 | 01:38 AM
dejahn23's Avatar
But If I hooked it up the normal way wouldnt it only be 2 ohms not the 4 my speakers need? heres a GENERAL pic I found on the rockford fosgate website that resembles the one in the manual.
But I dont see any pics the show the set up for two 4ohms speakers
Old Jul 6, 2007 | 10:00 PM
dejahn23's Avatar
what is the regular way to hook the speakers up if the pic says thats 2ohms?
Old Jul 7, 2007 | 12:08 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
it says 2 ohm minimum. in other words you cant run lower than two ohms stereo on that. if you plug up a one ohm load your sucking.
Old Jul 7, 2007 | 12:09 AM
Chocolate_Boi_1Der
just as he stated and youll be fine.
jmlee44
Oct 2, 2022 02:13 PM
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
