wire colors
Old Jul 8, 2007 | 05:26 PM
blimblam's Avatar
wire colors
what are the ground, power, and 12v color wire on a 1996 maxima with bose system? thank you.
Old Jul 9, 2007 | 03:00 PM
blimblam's Avatar
....anyone?
Old Jul 9, 2007 | 04:07 PM
Bollwerk's Avatar
Not sure if it's the same as my 99, but according to my 99 FSM, the colors are:
ACC - L/B (Blue with Black stripe)
BAT - P/L (Pink with Blue stripe)
Light SW - R/L (Red with Blue stripe)
ILL Cont - R/Y (Red with Yellow stripe)
Then there is a DIN cord connecting the deck to the box that connects to the speakers, antenna, etc.
The ground on the schematic does not have a color labeled, as far as I can tell. But usually ground is solid black, IIRC.
Note - There are alot of schematics for the various types of Bose stereo options, but I was checking the one for Radio/CD player.
Also - In case you're not familiar with the terms, ACC means power that is switched on when you turn your car on. BAT is constant power even when the car is off.
Old Jul 10, 2007 | 09:31 AM
blimblam's Avatar
thanks. anyone else?? that has a 96 w/ bose?? or do i just connect the wires on the aftermarket HU to the wire harness then plug the harness into the stock harness?
Old Jul 10, 2007 | 10:15 AM
Strontium's Avatar
What harness are you using? There should be Power and Memory lead on it. The ground goes directly to chassis.
Old Jul 11, 2007 | 09:55 PM
viperxiv's Avatar
Semi-highjack: I am also in need of a color-code guide since I will be wiring a harness to hook up a Pioneer deck to my '03 (non-Bose).
Old Jul 11, 2007 | 10:37 PM
Strontium's Avatar
www.the12volt.com
Old Jul 11, 2007 | 11:12 PM
viperxiv's Avatar
Sweet... thanx!
msellas
Sep 23, 2015 09:16 PM
popdedop
Sep 11, 2015 11:17 AM
