Best choice amp for subs?
Old Jul 13, 2007 | 03:45 PM
20SE00's Avatar
I have 2 Kenwood KFC-W3011 12" 1200 peak 400w RMS subs and i have a choice between 2 amps
a JBL GTO 4000 600w amp
http://www.dealtime.co.uk/xFS?KW=jbl+gto+4000&FN=&FD=0
or a Sony XPLOD 600w amp
http://www.crutchfield.com/S-dV4OUFU...sp?i=158XM2100 (similar to this, not sure exactly)
could also use a recommendation on wires and a link to a site to buy them from
thanks
Old Jul 13, 2007 | 04:03 PM
Fast1one's Avatar
Out of those two choices, I would choose the JBL (link is broken so dont know the exact model number). Though you can probably do better if you buy used...
For wires and such, you can't really beat KNU...
knukonceptz.com
Old Jul 13, 2007 | 06:48 PM
The Law's Avatar
I R The Law
None! Talk to Don. Both links are dead.
Old Jul 13, 2007 | 06:54 PM
mendon99's Avatar
tastey wheat
oh boy
whatever you do, stay away from sony, their amps actually do explode.
Old Jul 13, 2007 | 07:36 PM
20SE00's Avatar
woops sorry, fixed the links
they are both used, the JBL is gonna cost me $100, and the Sony is gonna cost me $200 (with 2 Sony XPLOD 12's that ill sell for hopefully like $50, and a box)
and for the wires, im assuming i need an amp installation kit? not sure what else, pretty much a newb with this stuff
Old Jul 13, 2007 | 07:54 PM
blimblam's Avatar
get the JBL. its cheaper is better quality.
Old Jul 13, 2007 | 08:08 PM
Pearl96Max's Avatar
I tend to get a bit irritable
You guy are making recommendations and dont know the impedance yet?
Old Jul 13, 2007 | 08:10 PM
blimblam's Avatar
you're right, i didn't even click the links lol. now that i did, i see that those are multi channel and do do near the power needed for your subs, i suggest looking for different ones.
Old Jul 13, 2007 | 08:36 PM
20SE00's Avatar
the subs are 400w RMS max, 300w per sub from the amp isnt enough?
http://caraudiosecurity.com/shop/pro...s_id/1180.html
tri-mode: 2 x 100W + 300W for sub
Old Jul 13, 2007 | 08:41 PM
Pearl96Max's Avatar
At WHAT LOAD ?
We need the impedance of the subs. You can rattle off amps all day, but if theyre not compatable its useless.
Old Jul 13, 2007 | 09:38 PM
20SE00's Avatar
dont know man, i dont know anything about this stuff thats why im asking
heres a link to the sub specs, 4 ohms
http://shopping.msn.com/specs/shp/?itemId=783175881
Old Jul 14, 2007 | 10:03 AM
Fast1one's Avatar
Those are the newer JBLs, which suck...ehh
Old Jul 14, 2007 | 12:15 PM
mendon99's Avatar
tastey wheat
if its a dual 4, you'll only be able to get a 1 or 4 ohm total load.
if single 4, then its either 2 or 8.
need to find this out before we can help you further
Old Jul 14, 2007 | 01:39 PM
20SE00's Avatar
dual coil if thats what u mean
Old Jul 15, 2007 | 11:42 AM
20SE00's Avatar
well, it seems that everyone who has made a choice between the 2 chose the JBL, so thats probably what im gonna do unless Don can match me up with something better, or someone recommends something for around $100 shipped
Old Jul 18, 2007 | 08:12 PM
20SE00's Avatar
Update: the guy with the JBL backed out on me, so i just went out and bought a Pioneer GM-7300M
http://www.pioneer.co.uk/uk/products...00M/print.html
gonna wire it at 2 ohms
new question though, are these plugs for the subs?
other set says "Front" both have a red and white plug
Old Jul 19, 2007 | 05:03 AM
nismos14's Avatar
§è~® f®ÈÄk
You can use the rear or front for the sub amp.... but you will have no sub control through that HU.
You know you're only gonna get 250rms or 360 rms to your subs... You have not properly stated your voice coil config and failed to listen to anyone on the forum.
Old Jul 19, 2007 | 05:15 AM
20SE00's Avatar
im not looking for huge bass, the only reason i got 1200w subs was bc they were at a good price, they are 400w rms which is plenty of power for what im looking for
if you look up a few posts, i said they are dual coil, if thats not what you mean then i dont know what you are asking me
edit: also, why wont i have control using those plugs?
Old Jul 19, 2007 | 06:17 AM
mendon99's Avatar
tastey wheat
If the subs really are dual 2 each, you can get a total 2 ohm load to the amp.
you wont get control on that deck because those preouts are really intended for highs amps, you need a 'sub out' pair to get sub control at the deck.
Old Jul 19, 2007 | 07:59 AM
jrpaytonAlpha06's Avatar
I believe your subwoofers are single 4ohm, to receive a 2ohm load, wire them in parallel. Here's a diagram to show you how to wire them to receive 2ohms.
http://mobile.jlaudio.com/support_pages.php?page_id=160
You should receive total 360rms watts from your amp.
Old Jul 19, 2007 | 08:05 AM
nismos14's Avatar
§è~® f®ÈÄk
He already said they are dual coil.....
Old Jul 19, 2007 | 08:11 AM
I don't think they make that specific sub with dual coils...I may be wrong though
Old Jul 19, 2007 | 06:42 PM
20SE00's Avatar
ok ran all the wires and ran the power wire directly to the battery, and the system control wire to the power antenna wire so that the amp gets powered when the HU is on Tuner or CD, and is off when the HU is off
anything dangerous about that? or anything i should be careful about with this set up? the guide that came with the amp said to wire it to the ignition switch so it had power when the car was on, but id rather not have the amp powered up if not gonna use it
Old Jul 19, 2007 | 06:46 PM
STILLENGLE's Avatar
IF wanted to get serious go with JL Audio. but there really $$$$
Old Jul 19, 2007 | 07:23 PM
slickrick's Avatar
I disagree...JL is terrible for the $.
Old Jul 19, 2007 | 09:05 PM
Pearl96Max's Avatar
+1 Your paying that $$$$ for the name, not performance.
Old Jul 19, 2007 | 09:20 PM
1996blackmax's Avatar
I'm pretty happy with mine ...................
ofcourse I also did not pay nowhere near what these are selling for either
Old Jul 19, 2007 | 09:22 PM
Pearl96Max's Avatar
You also dont have a JustLousy amp ... which IS what we are talking about here n00b.
Old Jul 19, 2007 | 09:30 PM
oops .......
Old Jul 20, 2007 | 08:26 AM
Batxel's Avatar
blah
lol at this whole thread ~ I needed a good laugh
Old Jul 20, 2007 | 10:18 AM
mendon99's Avatar
tastey wheat
ah **** really? im selling everything i own then.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Taino14
Sep 24, 2015 02:51 PM
