Need Help ..Tweeter Popping?
Old Aug 13, 2007 | 01:40 PM
Scooobay's Avatar
This morning my tweeters starting popping when i turned my music almost all the way up, for example 57/62 and varying from different songs. I noticed it was in the 5hz so i tried buying some new tweets and replacing them. Still getting the same pop, so it's not the tweeters, it's happening if i use rather a cd or my Mp3 Flash drive on my HU . If i turn 5k all the way down on the Eq then of course the noise goes away but so does my music. Any Ideas? Cant be the tweeters, i tried 3 different sets. All new.
Old Aug 13, 2007 | 01:51 PM
slickrick's Avatar
57/62 is too high...re-adjust your gains because that Pioneer radio is clipping its signal...have your max volume set around 43-46.
Old Aug 13, 2007 | 02:27 PM
filtor1's Avatar
What slick said. Sounds like your clipping the amp.
Old Aug 13, 2007 | 05:54 PM
nismos14's Avatar
§è~® f®ÈÄk
I'm guessing you mean 5000hz but either way they ^ are correct.
Old Aug 13, 2007 | 05:56 PM
Scooobay's Avatar
even though i dont have an amp running the interior's ? I was having no problem for awhile. i have an aftermarket HU. Max volume is 62 ...sayin i shouldnt put it past 46? ...that sounds odd....
Old Aug 13, 2007 | 05:57 PM
Scooobay's Avatar
your guessing correct sir, lol...but for real, i shouldnt set my volume past 46 even though my Hu goes to 62? hell i cant even go past 55???? ...i dont have an amp on the interior speakers...keep in mind, only my subs
Old Aug 13, 2007 | 06:05 PM
nismos14's Avatar
§è~® f®ÈÄk
You don't want to go that high on the volume because it causes distortion. Just like you don't want to go beyond 3/4 gain on amp because it usually causes distortion unless your signal is just that weak.
Old Aug 13, 2007 | 06:09 PM
Scooobay's Avatar
mmm..cool i guess..guess i'll have to keep it low, argh...that still doesnt solve the problem though, this wasnt happening at all before..and now it is, which means a problem exists, any idea of what it could be ?
Old Aug 13, 2007 | 06:26 PM
nismos14's Avatar
§è~® f®ÈÄk
Maybe the radio's outputs have began overheating.
Old Aug 13, 2007 | 07:59 PM
Pearl96Max's Avatar
I tend to get a bit irritable
You have caused this problem over time by doing what you shouldnt be to begin with.
Old Aug 13, 2007 | 08:00 PM
Pearl96Max's Avatar
If your car is capable of doing 140mph does that mean you should do it regularly? How long do you think the engine will like you?
Old Aug 13, 2007 | 08:15 PM
Scooobay's Avatar
mm..Touche..time to get it replaced. thank gawd for warranty,
Old Aug 13, 2007 | 08:19 PM
Pearl96Max's Avatar
Do yourself a favor and get an amp before reinstalling.
Old Aug 13, 2007 | 11:31 PM
Scooobay's Avatar
for the interiors?
Old Aug 14, 2007 | 05:08 AM
nismos14's Avatar
§è~® f®ÈÄk
Yes for the interiors
Old Aug 14, 2007 | 08:24 AM
Scooobay's Avatar
will do .thnx for the input guys..
Old Aug 14, 2007 | 01:09 PM
Bollwerk's Avatar
deck power FTMFL
Old Aug 14, 2007 | 01:16 PM
nismos14's Avatar
§è~® f®ÈÄk
^ x 11283749087091307850982093849082093840 billion
Old Aug 14, 2007 | 07:10 PM
Scooobay's Avatar
didnt know it was that needed..im slowly but surely getting up on my audio game...question...can a mono amp run 2 sub's? ...to me it's an obvious no..but i want your inputs as to if it's possible
Old Aug 14, 2007 | 07:37 PM
nismos14's Avatar
§è~® f®ÈÄk
You can run as many subs as you want off a mono amp as long as the final ohm load is fine for the amp, and as long as you have the subs wired properly.
Old Aug 14, 2007 | 09:12 PM
slickrick's Avatar
Don't do anything until you find a decent amp for the interiors...most significant audio upgrade I did (4 years ago).
Old Aug 15, 2007 | 03:21 PM
Bollwerk's Avatar
http://www.bcae1.com
Old Aug 16, 2007 | 07:07 AM
Scooobay's Avatar
Thanks for all the info guys. I'll get an amp. I went to bestbuy and got my HU replaced already,and bought an amp, hooking it up later.
Old Aug 16, 2007 | 01:21 PM
nismos14's Avatar
§è~® f®ÈÄk
4 channel amp? Best buy?!?! How much did you spend? Why not make the 10 minute drive to Don's house and get a better amp from him?
Mahmuth
Aug 16, 2024 08:23 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
jsmith24
Feb 1, 2016 12:35 AM
Excalibur23
Oct 13, 2015 04:33 PM
