Equalizer suggestion?
Old Aug 22, 2007 | 06:23 PM
svojs's Avatar
My 99 Bose HU finally stopped working. I am just too lazy to repair it with "CD Err" code. Thus, I decided to replace the BOSE HU and keep the BOSE amps/speakers.
I have ordered a SONY CDX GT-310 HU, the Scosche OEM adapter with gain control and the attenna adapter from Crutchfield. It should arrive in one week.
Since I am not planning to install sub woofers, I think GT-310 is just meet my needs with one pair "preamp" output.
My major question is, with such set up, is it worthy to add an equalizer? Personally, I love the look of in-dash 1/2-DIN equalizer units such as Kenwood KGC-6042A. Also, I have more questions about equalizers:
1) Does it worth it? I mean, with BOSE amp/speakers, the sound quality improvement might be limited. However, I might dump all BOSE components later if they ever stop working in the future.
2) What equalizer to choose? in-dash unit or 20-band big one that can be mounted under seat? The GT-310 is single DIN unit. I will have one more DIN space available.
3) Should I stick with big names like Kenwood, Alpine, SONY, Clarion... or other brands floating around such as Phoenix Gold, EQX....? Forget about those "Made in China" cheapo like KOSS/BOSS/Lanzar or no name.
Please chime in and share your opinions/experiences, Maxima Audio gurus!!!
UPDATE: I ended up buying an used SONY XE-90 Mk II graphic 9-band EQ. It's on the way.
Old Aug 22, 2007 | 06:33 PM
nismos14's Avatar
§è~® f®ÈÄk
You could have just gotten a GOOD headunit that has a built in eq.
If you're thinking about adding speakers and an amp later on then getting a headunit with a single set or pre-outs is a bad move.
Old Aug 22, 2007 | 06:42 PM
svojs's Avatar
Not quite understand. Please educate me.
Old Sep 7, 2007 | 12:43 PM
svojs's Avatar
After a lot of searching and reading, I think one set of preamp output is enough (for my general purpose use).
HU( preamp output, 1 pair RCA) -->
--> Equalizer--->(6 RCA, FR/FL/RR/RL speakers and SUB-R/SUB-L)-->
--> AMP ( FR/FL/RR/RL go to one, two or four AMP, SUB-R/SUB-L go to another AMP)-->
--> FR/FL/RR/RL speakers and SUB-R/SUB-L components
Is it correct?
If more than four speakers are ever expected, such as extra pair of tweeters, the second pair of preamp output would be required. That's all I understand.
Old Sep 7, 2007 | 12:58 PM
mendon99's Avatar
tastey wheat
technically, you can only hook up 1 monoblock, or 1 2 channel amp from a deck with 1 pair preouts (you could split the RCA leads, but you'd be running mono). Optimally, 3 are needed - 1 set for fronts, one for rears (or just 4 channel in stereo), and the last set for a dedicated sub amp, and you'd be able to control the sub from the HU. this is what you needed if you were planning on digging that deep for a system.
Old Sep 7, 2007 | 01:14 PM
svojs's Avatar
I understand what you mean. It's very true if I wish to connect HU to AMPs directly.
How about the external equalizer? Will it work as a preamp splitter that splits one pair input (from HU) into three pairs of output (front/rear/sub)?
Old Sep 7, 2007 | 01:42 PM
mendon99's Avatar
tastey wheat
depends upon the unit.
Should have really just bought a unit with 3 pair preouts and a solid EQ.
Old Sep 7, 2007 | 02:11 PM
svojs's Avatar
Yeah, the customer service/advisor of Crutchfield told the same story.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Pied
Sep 26, 2015 03:29 PM
