Best Rattle Mod
Old Aug 26, 2007 | 10:45 PM
viperxiv's Avatar
Best Rattle Mod
Alright guys, what's the best free - cheap thing you've done to subside rattles from your subs? The trunk of my '03 rattles like it's made out of plastic, even on moderate volume. I don't want something heavy like dynomat, I love my acceleration.
Old Aug 26, 2007 | 10:48 PM
D-Bo's Avatar
Droppin logs
Everything costs, you gotta pay to play...
Your best bet would be to donate to the org, search "sound deadening" and go from there.
Old Aug 27, 2007 | 01:09 AM
SilverGLE's Avatar
I'm watching you, boy...
Old Aug 27, 2007 | 04:55 AM
nismos14's Avatar
§è~® f®ÈÄk
Or simply click the link, the sticky for sound deadener.
Old Aug 27, 2007 | 08:06 AM
viperxiv's Avatar
There's gotta be something other than the stuff listed... I mean panels don't make noise by themselves, they're interacting and hitting against other pieces to cause the racket. There must be some key points where materials can be insulated from each other without having to coat entire panels.
I'm poke around myself this week and let you know if I find anything.
Old Aug 27, 2007 | 08:15 AM
nismos14's Avatar
§è~® f®ÈÄk
The weight you add with deadening is minimal, you could alway use expanding foam or something but why mess with that when deadening is tried and true?
Old Aug 27, 2007 | 08:20 AM
sterlingmaxima's Avatar
+1 deadening is not that heavy and def worth it I recommend using second skin it is fantastic and did a great job in my car.
Old Aug 27, 2007 | 08:39 AM
burnurass's Avatar
free mod = turning down the bass.
Old Aug 27, 2007 | 08:54 AM
nishfish871's Avatar
weather stripping(little foam strips) from home depot my be the cheapest but will only get the out the rattles if you know exactly where they are.
Old Aug 27, 2007 | 02:16 PM
Torgus's Avatar
fill the trunk lid with sand.
Old Aug 27, 2007 | 03:46 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Man up and buy the right products. Short on money? Then save up.
Old Aug 28, 2007 | 10:46 PM
viperxiv's Avatar
Originally Posted by nishfish871
...only get the out the rattles if you know exactly where they are.
Hence this thread.
Old Aug 28, 2007 | 10:54 PM
mtrai760's Avatar
'Trynna' is not a word
Like Don said, man up and do it right. If your THAT worried about keeping your 'speed', then get rid of those heavy subwoofers. What weighs more, a 40-50 lbs of box and subs, or a 2-3 lbs of sound deadener? Get real, this is a retarded discussion.
Old Aug 28, 2007 | 11:04 PM
SEmy2K2go's Avatar
Go BUCKS!!!
http://www.innerbean.com/housecor/bose_deck_fix.html
all the spoon feeding i'm doing tonight
Old Aug 29, 2007 | 08:19 AM
Bollwerk's Avatar
The reason things "rattle" from bass is because all things have a harmonic frequency at which they resonate (technically they have more than one). The only way to eliminate the resonance is to add more weight to the item, so the frequency it resonates at is lower. So technically, it doesn't eliminate resonance, it just lowers the point at which it resonates to be lower than what your sub creates.
Old Aug 30, 2007 | 04:28 PM
SMOKEYMOUNTAIN's Avatar
Dynamat License Plate Kit = $15
Old Aug 30, 2007 | 06:10 PM
maximal's Avatar
2-3 pounds? what kind of deadener are you using? that's like, maybe, a door kit...
user 11122324
42
Jul 18, 2022 03:35 PM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
jerrod99_se-l
Sep 16, 2015 02:39 AM
