can't get my new "jvc kw-avx800" to turn on
Old Aug 31, 2007 | 12:23 AM
seanwn's Avatar
so i bought the jvc along with the PAC ROEM-NIS2, and now i've got it all hooked up but the stereo won't power up. but the when the stereo is plugged in the antenna goes up. i checked all the fuses and double checked my connections to the pac. i'm really at a loss, please anybody got any help/suggestions? anything. the only thing i don't have plugged in is the big black plug for the antenna, but that shouldn't keep it from comin on should it?
Old Aug 31, 2007 | 02:55 AM
Maxima_Joe's Avatar
4th Gen Parts King
Yes the antenna wire is a ground.
Old Aug 31, 2007 | 09:13 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Sounds like you didnt ground the unit. It need to be via the frame, not through the harness.
Old Aug 31, 2007 | 04:11 PM
seanwn's Avatar
k, can i where could i get an adapter for the antenna? so do i ground it through one of the mounting screws? and why wouldn't you use the ground wire that's in the harness?
thanks a ton for the quick help guys, i've kind of got myself in a pinch tryin to get this finished.
Old Aug 31, 2007 | 04:55 PM
Pearl96Max's Avatar
Antenna Adaptor can be had at any shop or even BestBuy/Circuit City
The harness ground is non existant - goes to nothing and is not an actual ground.
Old Aug 31, 2007 | 05:54 PM
seanwn's Avatar
yeah!!! i got it grounded and it's now powering up, it doesn't pick up radio because of no adapter but it works.
second problem though, i've got no sound. any ideas? the pac adapter has two positives for each speaker; one labeled hi, and one labeled lo, i connected to the hi. should i be connected to the lo? i'm leary about frying anything.
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
RealityCheck
Oct 2, 2015 06:34 PM
salty318
Sep 29, 2015 01:21 PM
