firewall and 4gauge power wire
Old Aug 7, 2001 | 12:45 PM
PimpMoMax
Where on earth can I drill a hole or find on for that matter for 4 guage wire. I have heard that there is a hole to the left of the fuel filter, but is it big enough for 4 ga.? I have also heard something about drilling through a little metal peice next to the top left of the steering column? Where would be easiest and where exaclty is it? Pictures are MORE than welcome and would be GREATLY appreciated.
~Derek
Old Aug 7, 2001 | 09:34 PM
shortchaz's Avatar
3rd or 4th gen
if you have either car you can put the wire in the same spot behind the left front fender guard behind the wheel. when you pull off the wheel and take out the guard you will see the grommet where all the wires are, just be carefull, i didn't have any problems with either car, just take your time and don't rush yourself.
Old Aug 8, 2001 | 12:21 PM
khrfadz's Avatar
just make a hole anywhere on the firewall and run ur wires under the kickplates
Old Aug 8, 2001 | 02:26 PM
mzmtg's Avatar
Minister of Silly Walks
Re: 3rd or 4th gen
That's where my 4ga wire is. It's really easy to see once you get the fender liner off.
The Frye
Sep 2, 2021 11:03 AM
