Audio Install
Old Aug 19, 2001 | 09:08 PM
JHOVAMAX's Avatar
I was just wondering I know I have seen it on here before but is there a site that shows how to remove you r bose HU and install a new HU or should I just go and get in Professionally done.
Old Aug 20, 2001 | 07:39 AM
97SEMAX's Avatar
I just installed my sub and amp on saturday the toughest part of the whole install was getting to the bose.
Use the following technique:
(I have a 5spd if you have an auto I am not sure)
start at the bottom and pull the panel from around the shifter up. Best way is to apply force toward the front of the car and pull from the back. Now that the clip is disconnected it should slide right off after you disconnect the cig lighter. now you have a screw by the ashtray remove that and the ashtray will slide out. Now the fun begins...get a good panel popper (trim remover) from an auto store. Next thing that comes out is the vents and climate control. Place the trim remover on the clips and pop it off...there are 3 one in the middle, one on the left side and right side of the vents. This is the pain in the *** part...snap all the clips and use alot of force to get it out. from there you will see 2-3 screws remove those and the HU is easily accessible.
Hope that helps if you have any other questions let me know.
I just did mine saturday it isn't too hard but it is time consuming.
-97semax
Old Aug 22, 2001 | 11:47 PM
Matz
What year is your Maxima? I have a '91 with the Bose system, and just replaced the entire system (HU, speakers, added sub and 2 amps). Removing the Bose head unit was really easy. If you have the same year Maxima, I can scan the instructions for you and email them to you.
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
popdedop
Sep 11, 2015 11:17 AM
