Cigarette lighter -- power rating?
I am about to buy a DC to AC power inverter to run some small electronics. I was told that the power rating of the cigarette lighter is 150W and that I should not buy an inverter with a higher rating.
Can anyone confirm that this is the rating of that circuit?
Thanks!
Thanks!
Incidentally, can anyone recommend a good place in a 1992 Maxima GXE firewall to pass through wires for an inverter from the battery?
Thanks,
--- Rupert
Rupert Scammell
rupe@metro.yak.net
http://metro.yak.net:8080
Thanks,
--- Rupert
Rupert Scammell
rupe@metro.yak.net
So if we pull the fuse and upgrade it to a higher wattage? I'm basically looking to power a laptop, a Sony VAIO. The power supply to it says 19.5V, output 2.15A. Input 1.1A-.6A and it takes 100V to 240V. Anyone know if I can use a 300W Power Inverter with my 98 Max's cig adapter?
Sure! Just upgrade the fuse. That way while you are driving down the road computing, your car will catch on fire. Somewhere between the fusebox and cigarette lighter. The wireing can't handle more power. Wire directly to the battery and put a fuse in.
Rupe, pass the wire through near the floor on the same side as the battery. Just drill a small hole. 1/4 to 3/8 inch should be plenty for an 8 gauge wire which is more than enough for that power. Use some touch up paint on the edge of the drilled hole. When it dries insert a rubber grommet. They have them in numerous sizes at most hardware stores, or the electrical section of your auto parts store. Put the fuse within 18 inches of the battery.
So will the cig adapter power a 140W Power Inverter with no problems?
I'm power-clueless, as you can probably tell. heh.
