Center Console, What's holdin' the rear end down?
Assuming you mean the section that has the arm rest, the way to remove it is to 'snap' out you plastic piece surrounding the trans shifter. There are two screws that should be very visible. Then you go to the back of the armrest's console on the bottom sides (you may want to slide your seats all the way forward to access the screws better) and unfasten these screws. Unsnap the parking brake boot and lift the console up from the rear and slide it towards the front of the car. It should come off easy. Good luck.
Once you slide the seats forward you will see the screws. Make sure you put some kind of soft tape on the front edge of the console where it meets the dash. This helps out with squeaks/rattles.
vingodine
45
May 21, 2016 12:46 PM
wingsfan24
Aug 15, 2015 07:35 PM
