Need help with Bose wiring
I bought a 1995 Bose headunit to put in my '93, but I haven't been able to find any wiring charts which show all 16 pins. They all seem geared to installing aftermarket units in cars with Bose, so they don't include some of the unneeded pins. I've checked Matt93SE's FAQ, and sent email to installdr.com, but no response yet. If anyone has or knows of complete pin diagrams for 1993 and 1995, please let me know.
Thanks!
Dave
Thanks!
Dave
Re: Need help with Bose wiring
Thanks!
Dave
Thanks!
Dave
Originally posted by emax95
I hope you do realise that the bose head unit is not amplified, another words you need amps to run your speakers. If you have bose in your 93 already you should be all right.
Thanks!
Dave
Thanks!
Dave
Re: Re: Need help with Bose wiring
Originally posted by Yellowbrother
do u have haynes or chilton...i have the haynes and the diagram is in the back of the book...if still needed then i can look it up for u...
Dave
Re: Re: Re: Need help with Bose wiring
No, I have the FSM, but it's still a bit unclear. If you could post a copy of the diagram or just a listing of the pins, that would be great! Thanks a million, I really appreciate the help.
Dave
Dave
Re: Re: Re: Re: Need help with Bose wiring
i'm looking at the haynes now and it show's the bose system diagram...it has the wire color code and show's what it goes to but it doesn't have the pin layout from the bose headunit...unless u have the cable harness goin into the 4th gen bose i can't really help...sorry...and i don't have a scanner to scan the diagram for u...
blue or blue / black - acc
red / yellow - ill cont
red / blue - light sw
green / white - amp on signal
brown - frsp lh (-) amp
yellow - frsp lh (+) amp
nca??? - grd
light green - frsp rh (-) amp
purple - frsp lh (+) amp
red - rrsp lh (+)
green - rrsp lh (-)
nca??? - grd
pink - rrsp rh (+)
blue - rrsp rh (-)
blk / red - ant sig
Re: Re: Re: Re: Re: Need help with Bose wiring
pink or pink / blue - bat (back up)
nca??? - grd
red - rrsp lh (+)
green - rrsp lh (-)
nca??? - grd
pink - rrsp rh (+)
blue - rrsp rh (-)
blk / red - ant sig
nca??? - grd
red - rrsp lh (+)
green - rrsp lh (-)
nca??? - grd
pink - rrsp rh (+)
blue - rrsp rh (-)
blk / red - ant sig
