Measure amp watts?
Old Oct 31, 2000 | 11:56 AM
wilhelm's Avatar
Is there a way to get a true measure in watts for an amp? I have an ADS 640 6 channel running 40 to front BA seperates and 120 to each jl 10w0 in the trunk. I originally had 1 10w0 and it wasn't enough so I had a box built for 2 10w0 and it sounds better at high volume but doesn't seem like that much more bass at low volume.
Old Oct 31, 2000 | 02:31 PM
Matt93SE's Avatar
STFU n00b!
Well, you could do a CRUDE measurement by finding the DC resistance of your subs (unhook from the amp and check them with a multimeter)
now hook them back up and measure the voltage from the amp..
use a basic circuits equation, and you'll get a rough estimate..
P= V*V/R
you know voltage (V) and resistance (R), thus if your amp was putting out 10V and your speaker load was 4 ohms, you'd have 25W of power.
This could (and probably will) be off by as much as 50% though, because speakers impedance (a complex resistance) varies based on the frequency, and you'll get different output levels simply because of that..
Old Oct 31, 2000 | 02:42 PM
Micah95GLE's Avatar
That amp puts out 41 watts per channel (actual output).
[Edited by Micah95GLE on 10-31-2000 at 05:24 PM]
Old Oct 31, 2000 | 02:48 PM
Botos's Avatar
You could take it to a shop and pay them to bench test it, though this leads me to the question of what kind of setup <i>they're</i> using? I'd imagine you have to measure both the voltage and resistance in real time and calculate power from there...
Old Oct 31, 2000 | 04:06 PM
amax935's Avatar
a/d/s ?
I have seen a car audio mag with a test at 37 watts. I have the 840 it was decent driving a/d/s 6As biwired and two JL 10-4s bridged. If you can by-wire the BAs try bridging out the drivers, and running the tweets at 40. I did that with the other two channels running rear fill. It is f#$%KING FANTASTIc.
Subs are BA pro 12.5s 2 Ohm series with a bridged Alpine MRV 1000. Yeah bayyybeee!
AaronL
Nov 15, 2020 11:52 AM
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
