Dvc
Old Oct 12, 2001 | 06:39 PM
KLoWnPR109's Avatar
Dvc
What exactly does this mean? I've been reading some stuff but it doesn't really make sense. It says that they have wiring flexibility. What does that mean?
Old Oct 12, 2001 | 07:08 PM
93 SE's Avatar
dual voice coil,able to get different ohms ,thats all i know
Old Oct 12, 2001 | 07:20 PM
ispeed's Avatar
Re: Dvc
dvc = dual voice coil
yes you have more wiring options, but it all depends on what you want to accomplish. for instance ... say you have an amp that is stable to 4 ohms bridged. Now at that point the amp is pushing the most power and you want take advantage of this but 2 4 ohm subs can't be wired to that config. If you have a dual 2 ohm voice coil sub though you can get the correct ohm load. It is confusing when you first start looking at it, but once you get ohms down it will flow it a little easier. I admit that I still get a little confused sometimes...
Old Oct 12, 2001 | 09:55 PM
mb1's Avatar
mb1
Re: Re: Dvc
Not meaning to argue with you, but the example you gave is not a very effective one. Yeah, you can get a 4ohm mono load from a dual 2 ohm coil sub, but you can also get it from a single 4ohm sub. I think what you meant was if you have 2 dual 4ohm voice coil subwoofers, then you could wire them into 4 ohms, which you can't do with 2 svc 4ohm subs.
Old Oct 13, 2001 | 06:04 AM
ispeed's Avatar
Re: Re: Re: Dvc
yeah I realized that it was not the best example, but just wanted to be able to show that with only one sub you can get differenent wiring configurations. Instead of having to get two subs to get specific ohm loads, you can get 1 dvc sub and wire to the desired effect. And yes with my example, he could just use a single 4 ohm sub on that bridged amp rather than a dvc at all.
check out jlaudio.com and look through their tutorials section for a picture representation of dvc wiring diagrams and the ohm load they achieve.
Old Oct 18, 2001 | 11:21 PM
CanuckAMP's Avatar
Re: Dvc
Basically it's two smaller voicecoils instead of one larger one. The voicecoil is part of the electro-magnet that drives the woofer cone. Each coil has it's own impedance since they are separate circuits. In a DVC subwoofer the combination of these circuits will relate to differing loads on the amplifier depending on how they are wired up.
For a better description of DVC wiring and subwoofers visit http://go.to/bcae
dpassino
24
Mar 26, 2003 04:35 PM
moemakaveli
Jul 1, 2002 08:45 PM
ny96max
Oct 12, 2001 07:09 PM
CandiMan
Jun 27, 2001 04:46 AM
