Scosche adapter wiring question
Old Sep 13, 2007 | 11:29 PM
Jatan's Avatar
Doesnt let me search this section
My Bose CD player died and I have a JVC MP3/CD HU laying around so I'm putting that one in mine (bought the Scosche amplifier & the antenna adapters from Crutchfield)
Anyways, I connected all the wires from the Scosche adapter to the JVC harness (all the color codes matched up so it was easy):
8 speaker wires
red/yellow - ignition/power
solid blue - power antenna
solid black - ground
orange (dimmer) & blue/white (amp on) left disconnected - put electric tape on the wire ends
Whats the black wire with white stripe for on the Scosche harness? I alrdy connected the solid black wire to the HU's ground wire - do I leave this one disconnected?
Old Sep 13, 2007 | 11:41 PM
whitem1ke88's Avatar
8 speaker wires
Something makes me think it's amp remote or amp ground? It sounds familiar although I believe remote is usually blue/white
Old Sep 14, 2007 | 04:04 AM
Jatan's Avatar
The Scosche paper says:
Blue - power antenna
Blue/White - amp remote turn on
Black - ground
Doesnt mention anything for the black/white wire - it could be the amp ground like you said, but wanted to make sure what the wire was for before I hook everything up to the car
Old Sep 14, 2007 | 05:26 AM
nismos14's Avatar
§è~® f®ÈÄk
Black / white is amp ground, you don't HAVE to ground it as the ground in the harness should take care of it, however you can. Make sure you have grounded your radio to the chassis not just in the harness.
Old Sep 14, 2007 | 06:35 AM
Jatan's Avatar
Old Sep 14, 2007 | 12:43 PM
svojs's Avatar
Look closer! There are very fine prints on the wires of Scosche adapter.
Yeh, I think blue/white is the remote amp turn on signal. You should connect it to turn on your Bose amps.
Old Sep 14, 2007 | 06:25 PM
Jatan's Avatar
Just realized that after hearing no sound from the speakers lol
HU only has blue/white - remote lead or power antenna
Scosche has both blue power antenna & blue/white remote amp
Where do I connect the Scosche remote amp wire to? If I connect it to my HU's power antenna/remote lead wire then where does the solid blue power antenna wire on the Scosche connect to?
Edit: looks like I have to connect both Scosche blue & blue/white wires to the HU's single blue/white wire and the antenna will be on all the time:
http://forums.maxima.org/showthread....emote+amp+wire
Old Sep 16, 2007 | 02:46 PM
Jatan's Avatar
Thanks for the help guys - everything works now. Connected both amp & antenna wires to HU's single blue wire and also connected 1 ground to the harness and 1 to the chassis. Adjusted all 4 Scosche gains to about 1-2 o'clock and the JVC HU from our other car works just fine with the Bose
Had a dash kit laying around from our last year's totaled Accord so I just used that (no point in spending another $20). I couldnt bolt the pocket part to the dash so I stuffed a piece of plastic from the back in between the JVC HU and the pocket (taped it down so it wouldnt fall out lol) and the dash kit appears to be secure =P
If anyone needs the Scosche adapter ($40) and/or the antenna adapter ($13), use PA156 for free shipping on Crutchfield.com
Didnt have any batteries for the camera so I took pics after the install
Old Sep 17, 2007 | 10:14 AM
svojs's Avatar
So whenever you turn on the HU, the antenna gonna rise? Gess your HU is lack of the remote ant signal.
Old Sep 17, 2007 | 11:56 AM
Jatan's Avatar
Yea the antenna stays up all the time, but I dont mind - I have the JVC KDG-220 (which is now replaced now by the 230 model)
Its a cheap/decent HU so I dont really care. Retail was for $100 but I got it for around $60 back in June/July 2006 - I bought 2 of them for our 2 other cars that didnt have CD players
Old Sep 17, 2007 | 11:58 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
So how does the BOSE system sound with your new HU?
I just got a new Pioneer HU that I want to put in my BOSE system. Is this scosche adapter the best way to go? Is there anything wrong with just using a maxima harness to splice the HU in without using an adapter?
Old Sep 17, 2007 | 12:09 PM
nismos14's Avatar
§è~® f®ÈÄk
Which pioneer is it?
JaTaN you COULD put a switch on the antenna wire and use that to control the antenna, I did that with my 240sx.
Old Sep 17, 2007 | 12:51 PM
Jatan's Avatar
Too lazy to put in a switch - I dont mind if the antenna stays up (mine only goes up 1/3 of the way anyways, I'll have to spray it down with WD40 eventually)
Use the free shipping code I posted above if you're buying from Crutchfield
There is a cheaper Metra harness which uses RCA wires I think, but I just went with the Scosche for $40
Some people dont use the adapter, some people use the Metra, and some use the Scosche/PAC and its working fine for them so its up to you on buying the adapter - I didnt want to risk the speakers blowing
Just search for "bose adapter" or something like that in the 4th gen section since you cant search the audio section
http://forums.maxima.org/showthread....t=bose+adapter
The sound is a little better than with the Bose HU and you also have more settings to play with to adjust it to your liking (of course you'll get better sound by replacing the speakers but I didnt want to waste that much money). I'm just happy that I can use MP3 CDs now so I dont have to switch CDs often
Old Sep 17, 2007 | 01:08 PM
nismos14's Avatar
§è~® f®ÈÄk
Metra 70-7551 is easier but only recommended if you have a headunit with 4volts or > pre-outs.
Old Sep 17, 2007 | 04:04 PM
Vlasic's Avatar
Im going to put in a Pioneer DEH-6900UB.
I just looked up my deck and its RCA preouts are 4 volts at 100 ohms, I assume Ill be fine using the Metra adapter?
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
