removal of rear speakers
Old Oct 17, 2001 | 06:28 PM
MADMAN's Avatar
Does anyone has some basic instrutions on how to remove the rear speakers?
Old Oct 19, 2001 | 12:06 AM
Nismo's Avatar
Re: removal of rear speakers
you need to remove the rear seat so you can lift up the rear deck to gain access to the speakers. basic enough? just pm me if u need more instructions
Old Oct 19, 2001 | 02:38 AM
MaineMax's Avatar
OK - You need to remove the back seat and shelf to get to your rear speakers.
1.) Remove the rear seat bottom cushion. ( Pull on the 2 plastic rings on each edge. )
2.) Remove the 2 bolts on the outside edges of the seat back.
3.) Fold down the arm rest and door behind the arm rest. Lift the carpet and remove the 2 bolts. Push up on the seat back to remove.
4.) Remove the 3rd brake light assembly.
5.) Pull back the door edge molding.
6.)Pry out on the rear pillar trim panels to release the clips. Let them hang by the rear seat belts.
7.) Pry up the rear deck panel and slide it toward the front to remove.
8.) Now you can get to your speakers
Good luck.
Old Oct 20, 2001 | 04:07 PM
MADMAN's Avatar
Thanks guys
Good luck.
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
Huttig2009
Sep 25, 2015 03:31 PM
AcuraLegend
Sep 22, 2015 04:22 PM
A32goldylocks
Sep 2, 2015 06:39 AM
