Recently Bought a Capacitor
Old Sep 25, 2007 | 10:24 AM
maxima_man1992's Avatar
I bought a capacitor for my stereo cause my headlights would dim whenever I hit a hard bass line on the subs. I have one question. Is there a certain way you are suppose to charge it? Ive never done this before so some help would be great.
Here are the specs:
Pass-Through Design
1 Farad
digital display
up to 1,000 W RMS
16 Volt Rating
20 Volt Surge
24K gold plated terminals
3-1/16" D x 9-5/8"H
Thanks,
Maxima_man1992
Old Sep 25, 2007 | 10:28 AM
kostya.lyt's Avatar
did you buy it new? Instructions should come in the package...you hold a resistor in-line with the power wire...
Old Sep 25, 2007 | 11:19 AM
nismos14's Avatar
§è~® f®ÈÄk
Big 3 would have been cheaper and 10 times more effective than this garbage.
Return the cap.
Old Sep 25, 2007 | 11:22 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Just return it and save your money for something useful.
Old Sep 25, 2007 | 05:07 PM
arkainshadow's Avatar
ya return it, if they wont take it back, i believe you can blow them up. so ive heard, never tried it. maybe you can let me know if thats true. bridge the + and - side and run away from it... will benifit your system more that way.
Old Sep 25, 2007 | 08:17 PM
its lightning audio... I dont know much about capacitors, and plus my system was only 400 bucks but its all kicker componets. But if I were to get a new one would I beable to hook it up to a battery charger and let it charge or can it just hook up with only the battery?
Old Sep 26, 2007 | 04:47 AM
nismos14's Avatar
§è~® f®ÈÄk
If you want to screw up your electrical system then charge it up and install it.
Old Sep 26, 2007 | 05:31 AM
Matt93SE's Avatar
STFU n00b!
that's very funny guys. can you provide CONCRETE PROOF that a capacitor is going to damage this guy's system?
been running one in my car since 1998 and it hasn't done a thing to mine. :shrug:
Old Sep 26, 2007 | 01:40 PM
justinny's Avatar
its a capacitor
it charges when it gets power
it releases when a large load is put on the system
you have to discharge it before removing it
if you charge it and then install it it may discharge and blow your ecm or something else expensive
make sure you disconnect the negative battery terminal before you install it or mess with anything electrical
Old Sep 26, 2007 | 01:50 PM
bluefire's Avatar
IVE ALWAYS RUN A CAPACITOR IN MY CARS AND NEVER HAD A PROBLEM.
you should read the directions that came with it ,mine you hook up power and ground(no amp hook up yet) and start the car. let it charge until no more. then tap the amp in to hte cap.. . My rf cap came with a fuse hookup to do all this but i dont think u need it.
http://i229.photobucket.com/albums/e...4/P1000573.jpg
Old Sep 26, 2007 | 04:32 PM
Bollwerk's Avatar
Caps may not harm your system when used properly, but they are a lazy man's solution to a larger problem. It is a better practice to upgrade the "big 3" wiring and if you still have a dimming problem, get a higher output alternator. However, caps are "flashier", "easier" to install (although the big 3 wires are pretty easy to replace) and subject to all sorts of marketing hype. Hence their popularity.
Old Sep 26, 2007 | 07:08 PM
Pearl96Max's Avatar
Same here, they actually come included INSIDE all of my amps.
Old Sep 26, 2007 | 07:45 PM
filthysanchez09's Avatar
Make a coil gun on the front of the car
Old Sep 26, 2007 | 09:29 PM
I intalled it and it works fine i dont know what you guys were talkin about, my friend said he had the exact same kind i do in his talon he has and it works fine for him.
Old Sep 28, 2007 | 12:53 PM
BLK2BLU's Avatar
Originally Posted by Matt93SE
t
Yeah, it hasn't done a thing, thats the problem.....
Old Sep 28, 2007 | 08:55 PM
filtor1's Avatar
Did it solve your dimming problem?
Old Sep 28, 2007 | 08:58 PM
Pearl96Max's Avatar
So please humor us and tell us Exactly what it IS doing then..
2012Maximus
Sep 10, 2015 12:50 AM
Violator
Sep 9, 2015 10:14 AM
nbstriker10
Sep 4, 2015 04:26 PM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
