???Bose Amp comes on when it wants?????
Old Oct 1, 2007 | 07:16 AM
bi30's Avatar
sup everyone,
a little problem.
i have a 2000 i30 and for some strange reason the amp, stock bose, does not come on everytime i turn on the music. i also have a kicker amp hooked up. i took off my sub off to move some stuff and that's when i notice the amp comes on sometime. the aftermarket amp is not hooked up to the bose amp, i got the Pac unit and wired the amp straight from the head unit.
any thoughts, comments on this.
thanks
Old Oct 2, 2007 | 10:58 AM
svojs's Avatar
Check the signal to turn on the Bose amplifiers. I bet you tap this signal to turn on your aftermarket amps and sub amps. Make sure this signal is solid, without any extra load while running Bose only.
Old Oct 3, 2007 | 08:08 AM
bi30's Avatar
thanks for the tip, but i did not tap into the bose amp at all. i not sure now if it's the bose amp or the bose sup at fault. how do i check that??
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
