Amp Install?
Old Oct 12, 2007 | 09:40 AM
maxima_fan_boy's Avatar
Amp Install?
Ok i need some help here. I am going to be installing my new subs tonight and i was wondering where is the best place on the firewall to drill a hole to route the power cable threw? I have 4th gen max if that helps any.
Old Oct 12, 2007 | 10:10 AM
eng92's Avatar
There is no need to drill any holes.
Remove your left wheel and fender liner. You will see a wiring harness and the hood release cable. Just run your power cable along side those.
Old Oct 12, 2007 | 10:17 AM
AlpineGt66's Avatar
^ don't need to do that either, there is an existing empty hole in your firewall already its like in the middle. just look for one.
Old Oct 12, 2007 | 10:28 AM
eng92's Avatar
That hole is already filled with a WBO2.
Also, with the method I suggested, the wire is completely concealed and does not see any engine heat.
Old Oct 12, 2007 | 11:17 AM
DcMaN's Avatar
i drilled a hole where the clutch pedal assembly would go on a manual. Because i am running 0 gauge. How ever i was also lazy and did not want to jack up my car and take the fender lining off lol.
Old Oct 12, 2007 | 11:40 AM
Ok thanks i might go the fender lineing route because i also have been meaning to clean out my cai which sits in the fender.
MaxLife17
Jun 27, 2019 01:37 PM
2kmaximel
Sep 16, 2015 03:19 PM
popdedop
Sep 11, 2015 11:17 AM
