tach wont relearn ? 791xv
Old Oct 27, 2007 | 11:40 AM
DcMaN's Avatar
I installed my 791xv 2 years ago or so, but recently i changed the computer in my car from the Geforce ecu, back to stock, now whenever i remote start the car it starts up but drops immediatly and when i try to relearn tach it wont flash blue. Anything that can be done ? It won't even stay running if i start the car, press the * twice, and remove the key it just shuts off once the key is removed from the ignition. The lights flash as if it were gonna work but it doesnt.
Old Oct 28, 2007 | 09:45 AM
kpr10is's Avatar
Where did you tap? Whats the voltage the wire is reading?
Old Oct 28, 2007 | 12:12 PM
DcMaN's Avatar
green white @ ecu. I soldered connection i know its ok.
Old Oct 29, 2007 | 09:39 AM
mendon99's Avatar
tastey wheat
im not familiar with the process on tach learn on the 791's, but perhaps check your other connections that have to do with learning the tach (during programming)?
...ie: I have to hold brake while the tach learns on my units. If the brake line is disconnected for whatever reason, obviously the programming wont work..
Other that, confirm you have a tach signal at the brain
Old Oct 29, 2007 | 10:19 AM
DcMaN's Avatar
yea its all there, the only thing i can think of, is the rpm switch for the variable intake is hooked up to the same tach signal @ the ecu. Maybe thats throwing it off ?
Old Oct 29, 2007 | 11:25 AM
mendon99's Avatar
tastey wheat
cut it and rule it out.
Old Oct 29, 2007 | 10:42 PM
DcMaN's Avatar
i did still didnt work lol, im stumped.
Old Oct 30, 2007 | 09:44 AM
mendon99's Avatar
tastey wheat
bad brain?
Old Oct 30, 2007 | 08:28 PM
JSMax's Avatar
Sold
check fuses in the brain. I have a compustar and it was acting weird. I took it in and from the problems I was describing, the installer thought it might be a bad brain. He checked the fuses and one was no good.
I don't know anything about your system, but that is something that I think could get overlooked.
goodluck
hope that helps.
Old Oct 31, 2007 | 05:53 AM
mendon99's Avatar
tastey wheat
the tach signal doesn't run through a fuse.
Old Oct 31, 2007 | 06:04 AM
DcMaN's Avatar
im gonna unplug the main harness for a bit, even though i know the dei alarms store the info even if there unplugged :\
Old Oct 31, 2007 | 06:24 AM
mendon99's Avatar
tastey wheat
if it turns out to be the brain, run it tachless. If your car is in decent shape you should be okay.
cheaper than getting a new one..
Old Oct 31, 2007 | 10:07 PM
DcMaN's Avatar
might just toss in the towel an dgetthe 5900 sst its all plug n play i think isnt it ?
Old Nov 1, 2007 | 10:10 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Had the same issue months back when I threw in my UTEC, went tachless and never had a problem since.
Old Nov 1, 2007 | 08:11 PM
DcMaN's Avatar
hmm ill swithc over to voltage sense and give it a shot.
conansriver
Sep 11, 2015 10:26 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
gizzsdad
Aug 19, 2015 01:01 PM
maximaham
Aug 7, 2015 01:11 PM
jetmax
May 1, 2001 12:18 AM
