Amp powers off itself
Old Oct 28, 2007 | 10:23 AM
skyjay617's Avatar
Hi guys:
I have a 5 channel amp with clarion head. Recently, the amp would power off itself all of the sudden without any protection light on. I had to turn off the headunit and turn it back on to make the amp sounded again. But the problem just goes on and off.
Do you guys know the reason? could it be the low voltage issue? but usually low voltage could also turn on the protection light, but it just didn't
Please advise
Old Oct 28, 2007 | 11:01 AM
spark plugs.'s Avatar
Hi, I drive a Maxima.
does it shut off with or without sound to the sub? if you disconnect the sub, does the amp still shut off?
my guess is you fried the amp
Old Oct 28, 2007 | 12:34 PM
skyjay617's Avatar
with the sub on, it powers 4 speakers and the sub.
what to do if i fried the amp? The guy ground the amp pretty well.
Old Oct 29, 2007 | 02:25 PM
bi30's Avatar
check the RMS on the amp and what RMS the speakers require.
I have the same problem, i have to buy another amp with highter watts.
Old Oct 31, 2007 | 12:18 PM
skyjay617's Avatar
Ok, I tried everything last night. I disconnected the amp, or disconnect the each speakers to test....problem still exists. i have stock speakers.
please advice....could that be the headunit? or the amp?
Old Nov 1, 2007 | 07:29 AM
choiiiiiiiiiii's Avatar
you need new fuses. take it out and examine it, if it looks like the tiny metal inside is broken apart, then yeah you need new ones.
see what kind ur amp has, then go to advance or any auto place and get the fuses. cheap fix.
i had that problem too. hope it works for you.
Old Nov 1, 2007 | 08:42 AM
Whitemax's Avatar
Disco Biscuit
One of two things are happening. either the amp is getting too overloaded and shutting itself off,(even though the protection light isnt coming on) Or theres an internal problem with the unit itself. If it was a blown fuse, the amp wont come back on at all. You mentioned the one amp powers the whole system. How loud are you playing it?
Since you also disconnected everything and its still doing it, you have an internal problem with the amp, and either need to send it off for repair, or get a new amp. How old is the amp? Whats the make and model? is it still under warranty?
Old Nov 1, 2007 | 10:05 AM
nismos14's Avatar
§è~® f®ÈÄk
Could be loose remote wire, rca's, ground, + terminals, anything.
Old Nov 2, 2007 | 04:27 PM
skyjay617's Avatar
I will try to examine the fuses...but i don't think it's the fuses tho because the amp still power on.
I have an Ample amp, i don't play that loud....
i guess i will take the amp down and send it to repair
Old Nov 2, 2007 | 05:17 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
i was about to say the remote wire too at times everyone over looks the simple stuff. good luck!
Old Nov 5, 2007 | 04:32 PM
skyjay617's Avatar
what could happen to the remote wire?
Old Nov 5, 2007 | 04:37 PM
godlyone's Avatar
ahhh! cliMAX!
make sure its not crimped anywhere along its path or maybe the connection at the HU is loose.
Old Nov 5, 2007 | 07:06 PM
pikers's Avatar
Make sure the power and ground is secure in its terminals. Also ensure the power isn't pinched someplace--but not enough to actually short it.
I had an amp once that (for some reason) the allen screw got ever-so-loose, and it would cause the amp to go off and on.
Old Nov 5, 2007 | 08:04 PM
AscendantMax's Avatar
just double check everything to make sure nothing is loose.
Old Nov 11, 2007 | 12:16 PM
peaksja's Avatar
My neighbor has a JL Audio 500:1 and had the same problem. Some newer amps have an auto shut off when a input voltage(RCA Audio) is not present. In his JL I just turned that switch off, where it will rely solely on the remote wire. Check your amp settings...... since you have looked over the basics.
Old Nov 12, 2007 | 01:22 AM
idtag's Avatar
Remote wire could be the simplest. Check for voltage at the remote wire when the amp shuts down.
Old Nov 12, 2007 | 01:27 AM
skyjay617's Avatar
i am sure it's the remote then.......because i just swap another amp on it...it did the same thing....it just powers off itself with no protection light....sigh...i need a day off to fix it
but thanks guys!!!
Old Nov 12, 2007 | 01:40 AM
SEmy2K2go's Avatar
Go BUCKS!!!
BOSE?
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
sliptap
Sep 30, 2015 05:57 AM
