Need help wiring my capacitor... Audio Gurus' come on in...
Old Oct 28, 2007 | 10:24 PM
BORQUA79's Avatar
nycmaximas member
Im running a single 12" Kicker L7, with a mono Kicker amp I believe Its a kx600.1
I just purchased a 2 farad Power Acoustik capacitor. I need help with he wiring. In the instructions its says that:
I need a distribution block? Do I really need this in order to wire it in?
I figure I run the Power from the battery to the Capacitor.
Then the Positive from the cap to the Amp???
The negative from the Cap to a Ground on the frame?
Any help before I fry my system or set fire to my car is appreciated.
Old Oct 29, 2007 | 09:36 AM
mendon99's Avatar
tastey wheat
You shouldn't have wasted money on the cap. they're useless, always, and running only 600 watts you shouldnt have a problem anyways
return it to the store?
Old Oct 29, 2007 | 11:30 AM
nismos14's Avatar
§è~® f®ÈÄk
Easy way to wire it is to throw it in the garbage.
Old Oct 29, 2007 | 11:36 AM
svojs's Avatar
No place for the cap! Either return it or get rid of it. Of course you can send it to me. I need big caps in the usage other than car audio.
Old Oct 29, 2007 | 12:06 PM
djfrestyl's Avatar
Suspension Yoda
Attach wire to garbage bag
Attach other end of wire to cap.
Throw garbage bag out window, and cap will follow.
Hilarity ensues.
Old Oct 29, 2007 | 12:08 PM
nismos14's Avatar
§è~® f®ÈÄk
It's only hilarious if you light it on fire first.
Old Oct 29, 2007 | 01:58 PM
bi30's Avatar
are you sure that amp is powerful for that speaker, what's the RMS.
Old Oct 29, 2007 | 09:27 PM
BORQUA79's Avatar
nycmaximas member
O.k. Where do I start???
mendon99:
Its not returnable. I was planning on running another 400 watts for my highs/mids... I have dimming of the interior gauges and heard It helped take some load off of the alternator??? (Oh It looked nice in the trunk as well) Thanks
nismos14: Thanks, but the garbage isn't an option.
svojs: I would only sell it, besides you can go to Virgina and buy some caps along with a Desert Eagle If thats your flavor...
djfrestyl: You know it would be funnier if I threw the cap out the window so that the garbage bag acts like a parachute floating down to the gutter below... lol (Oh positive or negative wire?? does it matter??)
nismos14: Nahh the flames would just burn the parachute...
bi30: Amp-300 Watts RMS x 1 @ 4 Ohms 600 Watts RMS x 1 @ 2 Ohms
Sub: 750 Watt RMS. You think this is a good match?
Thanks for your input and laughs everyone. Once again I'm asking If anyone else knows how to wire a Capacitor, thanks again...
Old Oct 30, 2007 | 04:57 AM
djfrestyl's Avatar
Suspension Yoda
And we're giving you sound advice that you don't need it, it is detrimental to your system, and a waste of time/money. If you ask for advice and we give it to you, but you don't want to take it, well you're just hanging yourself.
If your lights are dimming, upgrade your grounds, and do the big 3. A capacitor is a bandaid.
Seriously, some of us know what we're talking about.
mendon99:
Old Oct 30, 2007 | 06:33 AM
adampit's Avatar
I gave you the same answer on NYCMAXIMAS as these guys and you didnt read it i guess
Old Oct 30, 2007 | 09:25 AM
NismoMax80's Avatar
SuPeRmOd
ibgurussaywastedmoney
Old Oct 30, 2007 | 10:20 AM
filthysanchez09's Avatar
Make a coil gun in your car.
Old Oct 30, 2007 | 11:27 AM
djfrestyl's Avatar
Suspension Yoda
Already done
Old Oct 30, 2007 | 12:02 PM
bi30's Avatar
Not a good match for amp and sub, you need a amp with rms of at least 750 rms.
you can give the amp to me and buy another one.
i have the same problem, you don't need a cap.
Old Oct 30, 2007 | 04:01 PM
BORQUA79's Avatar
nycmaximas member
Not "sound" advice
Throw garbage bag out window, and cap will follow. Hilarity ensues.
Sound advice.. yay
And to let you know, I am taking all of your real "sound" advice... Like your "up grade grounds" and "big 3" (which I dont know what that is?)
I do know alot of you know what your talking about, because Im obviously asking you guys...
Dont take my sarcasim for not listening to you guys... Im just making a joke like the rest of you...
Adampit: Im looking at it as we speak, thanks alot..
Old Oct 31, 2007 | 04:49 AM
djfrestyl's Avatar
Suspension Yoda
Make sure the grounds on your amp match the gauge of your power cable. If you're running 8 gauge, upgrade to 4. Make sure the paint is sanded off the contact point where your grounding terminal for the amp connects to the chassis.
Big 3:
Battery negative to chassis
Battery negative to engine
Battery positive to alternator
Usually the big 3 is done with 1/0 gauge wire. Make sure the wire going to the alternator is fused.
Also, you're a supporting member. Information about the big 3 could be found if you searched.
Old Oct 31, 2007 | 02:23 PM
BORQUA79's Avatar
nycmaximas member
True, you beat me to it.. lol
Believe it or not, I actually do use the search... alot lol
Also, how big a fuse should I get for the alt-positive wire? In your opinion?
Thanks DJfrestyl
Old Oct 31, 2007 | 05:28 PM
djfrestyl's Avatar
Suspension Yoda
Thanks DJfrestyl
Stock alternator can put out what? 110amps? No more than that I'd say.
Can someone else confirm this?
Old Oct 31, 2007 | 08:47 PM
BORQUA79's Avatar
nycmaximas member
I read 100-125 amps one place 110 amps at another??? I guess a little over that is good?
Old Nov 1, 2007 | 01:53 PM
pikers's Avatar
nuts to navel
Fbana41
Aug 29, 2016 12:18 PM
D Mason
Jun 21, 2016 04:43 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
