ATTN: MaximaDave
Old Oct 24, 2001 | 09:13 AM
RICOiz704's Avatar
ATTN: MaximaDave
Im still in thought stages of a few things so im gonna run it by you...
Im still considering the Eclispe 7002 monitor paired with a eclispe headunit to fill the double din(is that possible)
Also if I was to run screens in the headrest..would that be compatible or be able to be a slave off of a 7002 powered by a PS2...and how long do you think Tweeter would have the 7002 at clearance prices...I know it's a mouthful and thanks in advance
Old Oct 24, 2001 | 09:19 AM
maximadave's Avatar
detailerdaveb@gmail.com
I'm down to 2 displays here in so cal out of 13 stores...the last 2 don't look that good. The replacement is the AV5101 and has on board video switching for rear monitors...if you plan on running rear monitors go with the AV5101 it also has 2 video inputs rather than 1 on the 7002. The AV5101 lists for $1200.00
Maximadave
Old Oct 24, 2001 | 09:21 AM
maximadave's Avatar
Yes, using the 7002 or AV5101 with their say CH5061 6 disc in dash cd changer to act like a double din, yes it will fit.
Maximadave
Old Oct 24, 2001 | 09:33 AM
RICOiz704's Avatar
When u say switching what do you mean? Does that mean u can either run the rear or just the front at one time and not simultaneously? Also you can run 7002 with headrest screens...so im pretty new at this and trying to get a clear view...I was aiming at the 7002 due to not wanting to pay a grand for a screen. And how much can I get a eclsipe head unit that can be used with a 70102 or are they all compatible...I really don't need anything fancy just sumthing to fill the din under the 7002
Old Oct 24, 2001 | 09:48 AM
maximadave's Avatar
The AV5101 allows you the driver to select what the rear monitors play. On the 7002 you can't. You can put a few things underneath the monitor to act like a double din:
The CH5061 6 disc in dash cd changer
DV3101 .5 din in das DVD player...make a special kit to make it a double din.
or just put a Nissan oem pocket underneath the monitor, which I did, and go with the 5083 trunk mount 8 disc changer.
Maximadave
Old Oct 24, 2001 | 09:54 AM
RICOiz704's Avatar
So whatever get played on the 7002 will get played on the rear monitors? But if u only have one Video source how would they be able to play different things anyhow? Excuse my ignorance please just trying to educate myself is all
Old Oct 24, 2001 | 10:06 AM
maximadave's Avatar
That is what a "video switcher" is. You can switch video sources from front to back.
Old Oct 24, 2001 | 10:24 AM
RICOiz704's Avatar
U can't play them simultaneously......
Old Oct 24, 2001 | 10:47 AM
maximadave's Avatar
Yes you can.....you can watch all 3 monitors with the same source playing through all of them.
Old Oct 24, 2001 | 10:52 AM
RICOiz704's Avatar
Hey Dave since you are such a fan of the AV5101 sell me your 7002
j/k...but I might grab a 7002 and a changer off ebay and get me a changer...or a 6disc in dash...whatever is cheaper
Thanks for your help
Old Oct 24, 2001 | 11:01 AM
maximadave's Avatar
No problem.
Be careful buying Eclipse on the internet...expecially on E-Bay. All Eclipse decks are coded with their own serial number and registered with Eclipse. They have an ESN lockout feature that most consumers use...
Maximadave
Old Oct 24, 2001 | 01:06 PM
PrinzII's Avatar
OG and counting...
Originally posted by maximadave
No problem.
Maximadave
....and I am one of those consumers.
Old Oct 25, 2001 | 05:45 PM
maximadave's Avatar
gramenis
Buyer/Seller Feedback
Feb 22, 2005 09:49 AM
replicant
Aug 7, 2002 08:39 PM
2002 SE TX
Nov 11, 2001 10:58 AM
