Installed new headunit now subwoofers don't work
Old Dec 3, 2007 | 04:28 PM
imported_D_Roc's Avatar
installed the new stereo and now my sub (stock) don't work nay idea why i hooked all the RCA jacks that was in the harness there was 4 total. did i miss something? i really need the sub
the car is a 2001 maxima se
Old Dec 3, 2007 | 06:26 PM
Strontium's Avatar
I take it, that's a Bose system? Only thing that I can think of is the amp turn-on wire (remote turn on, usually blue).
Old Dec 3, 2007 | 06:36 PM
if it's the wire wouldn't it effect the rest of the speakers too coz they all are connected tot he same amp?
Old Dec 3, 2007 | 06:55 PM
Strontium's Avatar
Scratch that. You are using the RCA outputs, from the deck. That will allow the door speakers to use the stock amps, but at very low volume ( I switched to line level outputs + LOC because of that). However, you need to have the remote turn on wire connected for the sub to work.
Old Dec 3, 2007 | 07:05 PM
i hooked that wire think i hooked it to the wrong one? every theing works good except the sub woofer (the most important thing to me)
Old Dec 3, 2007 | 07:08 PM
Strontium's Avatar
Well, the only thing that I can think of is amp turn on wire. Recheck your stuff.
Old Dec 3, 2007 | 07:47 PM
well just checked all wiring the woofer is working but very low bearly could feel it any solutions for that?
thanks
D
Old Dec 3, 2007 | 07:50 PM
Strontium's Avatar
thanks
D
Might be related to using the low level rca outputs, from the deck. I switched to hard wiring from the line level outputs, with a LOC (since you're basically double amping the speakers by doing this). How do the door speakers sound? Do you need to turn it up higher than with the stock head unit?
Old Dec 3, 2007 | 08:06 PM
the door speakers are fine in fact the sound is more quality than it was with the bose, also what is a LOC?
thanks
jskirwin
Jun 8, 2016 08:49 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
starman9215
Aug 11, 2015 06:51 PM
kenc15
Aug 5, 2015 08:29 AM
